Author Topic: chips  (Read 5513 times)
Offline Peter Drouin
    • A&P Saw mill LLC
chips
« on: January 19, 2016, 05:59:56 PM »
How much would a 100 yard box trailer full of soft wood chips weigh?
[just the chips]
Offline brendonv
  • Arborist
    • www.VorioTree.com
Re: chips
« Reply #1 on: January 19, 2016, 06:36:10 PM »
I've always heard 500lbs per yard as an average.
"Trees live a secret life only revealed to those that climb them"
www.VorioTree.com
https://www.facebook.com/pages/Vorio-Tree-Experts-LLC/598083593556636
    • A&P Saw mill LLC
Re: chips
« Reply #2 on: January 19, 2016, 10:09:07 PM »
Thanks for your input brendonv.
Offline VAMuleskinner
Re: chips
« Reply #3 on: January 20, 2016, 08:09:39 AM »
I am not sure of what the factory capacity is but I pull a 45' chip trailer.  We are allowed to gross 90,000 and I am averaging 30 tons of chips.  There is room for a little more in it though.
    • A&P Saw mill LLC
Re: chips
« Reply #4 on: January 20, 2016, 05:27:49 PM »
Thanks VAMuleskinner, I knew there would be 1 or 2 guys on here that new about chips and big trucks. :D :D
Offline thatchipperguy
Re: chips
« Reply #5 on: January 20, 2016, 07:43:01 PM »
We run 50ft chip van full of clean chips. Softwood will run around 34-37 tons. We have one 53ft and it averages 3-5 tons more per load. If the chip are whole tree they will weigh more due to the bark.
Offline buzzegray
Re: chips
« Reply #6 on: January 20, 2016, 07:52:11 PM »
Roughly, how much would 100 yards or a full load cost delivered to 20 miles away?
Offline Logger RK
Re: chips
« Reply #7 on: January 20, 2016, 08:16:25 PM »
We have a couple 45 foot chip vans and weight can very.  If it's green Aspen & to stay under 90,000 we go 2 the bottom of front vent(5 foot from front)then second vent back (about 15 feet from front) we fill it to the top and maybe 2 foot up the back door. And its around 85-90k. Soft wood like Balsum & Pine & a few month old Aspen  we can usually fill to the top of the back door(which is 4 foot high)Usually keep the front the same because it'll b loaded to heavy up front.
    • A&P Saw mill LLC
Re: chips
« Reply #8 on: January 21, 2016, 06:30:11 AM »
Thanks guys for the help. Had to get the paperwork done for the state. They want to know how much wood product I put out. Do it every year.
I sold all my chips by the yard, they want it in tons. :D
Offline Logger RK
Re: chips
« Reply #9 on: January 21, 2016, 07:05:34 AM »
Nice chip van & loader. We been thinking about putting 3rd axles on are's. Could haul 98k instead of 90k with tandem. With the added axle weight not sure if it's worth it? We hire trucks 2 pull r vans & they charge the same anyway I would think?Around these parts they measure chips in tons. And different species have conversion to cord. If I could figure out how 2 get my pictures in my album u could c r,one of a kind paint job on r vans. I'm kind of partial to Green & Black. When we got them they were white & said Extra on them. Figured y advertise 4 them. But in the last year or so I c a few other outfits getting there vans looking better. 👍😎
Offline WV Sawmiller
    • Green's Sawmill Services
Re: chips
« Reply #10 on: January 21, 2016, 09:19:33 AM »
   Way out of my experience level but just wondering how hard it would be to weigh a couple of samples. As mentioned by others the type wood and how long cut/dry makes a difference too.
    Might be something to add to the reference section here when done. Good luck.
Offline HiTech
Re: chips
« Reply #11 on: January 21, 2016, 03:09:46 PM »
Run a loader for awhile with a roll out bucket. It was 8.5 yd. and could be heaped to 10 yd. The trailers were 110 yd. 11 buckets of clean chips would fill them. I don't think they were that heavy. They were playground chips and pretty dry. The mulch was a lot heavier. 9 buckets of that was a load.
Offline loggah
  • Just hangin' around :)
    • Johnson Hollow Sawing and Shingle Making
Re: chips
« Reply #12 on: January 22, 2016, 07:02:34 AM »
Peter,Your chips will weigh less then green chips blown in a trailer with a chipper,i regularly got 25-27 tons in a 45' box when chipped the same day as skidded. Piled wood setting ,and drying,especially leafed out wood for even a few days would result in 2 or 3 tons less. Dumped into a open topped trailer even less. I used to load piled chips with my Michigan 275 loader and they fluffed up quite a bit resulting in less weight.
Interests: Lombard Log Haulers,Tucker Sno-Cats, Circular Sawmills, Shingle Mills, Maple Syrup Making, Early Construction Equipment, Logging Memorabilia, and Antique Firearms
    • A&P Saw mill LLC
Re: chips
« Reply #13 on: January 22, 2016, 12:06:39 PM »
That's why I sold them by the yard. ;D
Offline Logger RK
Re: chips
« Reply #14 on: January 24, 2016, 08:23:54 AM »
Wondering if others coat the inside of there chip vans with something during cold conditions to keep chips from freezing in?
Chips
Started by Chico on Wanted
Last post March 26, 2009, 06:45:15 AM
by Chico
Chips any one
Started by Peter Drouin on Sawmills and Milling
Last post October 20, 2014, 07:26:04 PM
by Peter Drouin
Fixin to tho some chips
Started by lynches lumber on General Woodworking
Last post March 01, 2012, 01:32:11 PM
by sandhills
Red paint chips.
Started by kensfarm on General Board
Last post March 11, 2017, 05:52:26 PM
by thecfarm
