anchor seal alternatives
Started by Alexis, March 21, 2010, 03:08:32 PM
Alexis
Hello,
I would like to know if there is an alternative product for anchorseal. I have some freshly cut joint that I would like to protect as soon as possible and don't want to wait for a delivery. It's for a shed so apperance doesn't matter too much
thanks
Alexis
shinnlinger
Whatever you have on hand will do something.  Aluminum roof coating, tar, driveway coating or Melted Parafin. These 4 will probably work as well as Anchoreseal, but the first 3 can stain and hide end grain and the 4th can be a pain.  Polyurethane and old house paint will do something for you, but not as well.
Dave
Shinnlinger
Brad_bb
If you have a Rockler store in any proximity, they carry end grain sealer much like Anchor seal.  Maybe thick latex paint in a pinch?  I'd prefer the green wood end grain sealer though.
witterbound
I've heard of folks using latex paint.
Raphael
We used to use bees wax to seal the endgrain on our bow blanks, it's a little nicer to work with than parafin.  I've also heard of people using old latex paint as well.
... he was middle aged,
--Godley & Creme
submarinesailor
Quote from: shinnlinger on March 21, 2010, 08:17:10 PM
Whatever you have on hand will do something.  Aluminum roof coating, tar, driveway coating or Melted Parafin. Dave
Tried the aluminum roof coating and I think it sucks.  After trying several of the others, I cannot find anything that works as well as Anchorseal  - or one of the others like it.
Bruce
frwinks
latex paint works, but I like the clear/yellowish hue of the anchorseal on finished joints instead of green latex paint (which is all I had at the time :D)
Alexis
I'll try the latex paint, since I have some on hand. Does lindseed oil works? It would sure be prettier!
alexis
Brad_bb
No, don't think so.  You need to seal the capillaries of the endgrain.
bub4e
If you have linseed oil, then use it, it is better than nothing.  If the end grain will be seen then it would be better than paint, just use multiple coats.  This really isn't rocket science, Anchorseal may work the best and be the easiest to apply, but if you don't want to spend the money or can't get it in time, then use what you have.   All you are doing is slowing the release of moisture.
