Finally registered
Started by BW_Williams, February 21, 2003, 11:35:23 AM
BW_Williams
Hey all, I finally took the time to register here, been hanging around a while.  Having trouble adding my tree on the members map. Do I need to post first, if so I guess this does it?  BWW
Support your local Volunteer Fire Dept.  (not by accident)
Support your local Ski Patrol (by snowboarding:)
Mayor of Millerdale, Washington, USA (by God)!
Welcome BW
The tree on the members map is easy but you need to pay attention to the Map and the Bio.  there is a software glitch and if you put your tree on after you write your bio then your bio goes away.  Be sure to save your Bio somewhere on your computer, like in an email or something, in case it gets erased.  There are lots of instructions for both.
Bibbyman
Welcome BW,
Lots of stuff to find out here on the FF.  Just keep looking and try the Help screen.  It really helps.  Also, the Knowlege base helps too on things like posting pictures, etc.
There is an answere for everything - if you can just find it. :D
Sawing since '94
