General Forestry => Tree, Plant and Wood I.D. => Topic started by: Don P on June 03, 2002, 11:30:37 AM
Title: Solved: Tulip Poplar
Post by: Don P on June 03, 2002, 11:30:37 AM
A name I've heard given to several trees, this is ours.
(https://forestryforum.com/images/YaBBImages/userpics/jun03.jpg)
Title: Re: Tree ID June 3
Post by: bjorn on June 03, 2002, 01:42:17 PM
poplar, tulip poplar, yellow poplar, liriodendron tulipera (something like that).
Post by: Don P on June 03, 2002, 03:16:46 PM
That's it Bjorn 8), the latin is actually liriodenron tulipifera :P(yaa, you made me go to the books :D).
The reason I posted the pic (aside from the pretty blooms) is up north aspen is often called popple or poplar. Not a big deal normally, but I and others have posted about using poplar for dimensional framing. Its strength is close to southern yellow pine. Aspen (bigtooth and trembling) is rated with the northern species, along with white pine, red pine, western red cedar, ponderosa pine, eastern hemlock, balsam poplar.
Not a reason to avoid the other woods but a reason to know exactly what you've got sometimes, a yellow poplar 2x8 joist can span 2 feet further under the same load than an aspen joist of the same size :o.
Title: Re: Solved: Tulip Poplar
Post by: bjorn on June 04, 2002, 06:08:37 AM
Where can I find span tables for tulip poplar? as I am cutting alot of this wood for my barn.  Thanks.
Post by: Don P on June 06, 2002, 08:55:48 PM
Hi Bjorn,
sorry to have dropped out for a couple of days, we travelled down to her Mom's. I'm starting to get the hang of this web tv.
I'm carrying a couple of engineering, span and code books back up with me and have more stuff already at the job in IL. Long story short, I don't have a table for poplar but am comparing design values from several sources (Fb and e values), doing the math then confirming by comparing the results to tables for species with similar design values that I do have tables for. I'll be back up there in about a week. IM me if that will work and I'll show you what I've got.
In VA be sure to answer questions appropriately. This is strictly an ag building you are proposing, strictly for farm use...there will be NO other uses...been there paid for that permit :D
Post by: Corley5 on June 07, 2002, 06:25:26 AM
So that's what tulip poplar looks like 8) 8)  The leaves look similar to a maple but different.  They do have pretty flowers.  What's there northern limit?
Post by: Ron Scott on June 07, 2002, 08:02:44 AM
I know its in West Virginia.
Post by: swampwhiteoak on June 07, 2002, 09:22:53 AM
Tuliptree range:
Eastern - Atlantic coast
Western - Around the Illinois state line, little piece of Missouri, and part of Louisiana
Northern - South Central Michigan and New York state
Southern- Gulf of Mexico and south central florida
In my not so humble opinion the best tulip grows in W.Va, Va, and eastern KY.  Basically the southern alleghennies and the cumberland plateau.
Post by: woodmills1 on June 07, 2002, 10:30:34 AM
we dont have it in NH but i do remember some fine specimins from my WVa days.
Post by: Ron Scott on June 07, 2002, 05:43:50 PM
One could almost hear it growing on the Monongahela National Forest in West Virginia. The Monongahela Decision against clear-cutting stopped much of its harvest however.
Post by: Don P on June 07, 2002, 09:22:16 PM
At home, north of the sy pine range, it is as fast growing as the pines and strong. Grows like a weed, the seed is viable forever and wants to sprout, I like it. It took over the old chestnut stands. While Jasper took us for a walk today on a nice greenway on the Broad River I learned that its a member of the magnolia family.
Post by: L. Wakefield on June 08, 2002, 01:31:29 PM
   And- believe it or not!- it is actually listed in the book Trees of Maine. As an introduced species of course- but says it does OK. I just love those trees! How high off the ground were those blossoms in the picture, DonP?   lw
Post by: Ron Wenrich on June 08, 2002, 07:19:38 PM
From logyard
(https://forestryforum.com/images/YaBBImages/userpics/pop1.jpg)
To carriage:
(https://forestryforum.com/images/YaBBImages/userpics/pop2.jpg)
To the grade pile:
(https://forestryforum.com/images/YaBBImages/userpics/pop3.jpg)
Poplar grows well in our area, but to get the large areas of sapwood, you need it to grow down south.  They need at least 1/3 sap for veneer.
It grows very well up to about 36".  The biggest I've sawn is about 40" and that takes a long time, since I don't have a top saw.
You get very good amounts of F1F and better lumber off of the butts and second cuts.  The lumber shown here is 10/4. destined for the Canadian markets.  I've sawn 16/4 boards that were 20" wide, and clear on both sides.  The lumber stackers hate when you do that.   :D
Here's something to ponder.  I was told that those large pillars on those southern mansions were made from quartered tulip poplar trees.  I have no way of knowing if that's true, but it would be a very large tree to be quartered into those sizes.
Post by: Jeff on June 08, 2002, 08:38:08 PM
Hey how come the picture of your carriage is backwards? Cause its a Canadian Morbark?
Post by: Don P on June 08, 2002, 08:50:56 PM
Those blooms were only a little over head high on a ~24" yard tree at home that I keep having the best intentions of limbing up. Its not unusual to go clear 32' in the woods and I've seen plenty go more. The old giant on the housesite was 6' across the stump...but unfortunately waist deep inside the rotten heart.
The largest I've seen was 2 men and a boy around cbh (circumference, boy height).
Our barn and rent house are both 24' wide with 12' spans. I framed with 2x10 joists 16" on center. The barn is loaded...with ag type stuff...wood, half a dozen engines, a truck, you know the usual :D
One joist failed, but from a spike knot in the lower side, bad grading on my part, other than that it seemed to be a good overkill size for that species and span.
A lot of clapboard siding was made from it. We ran paint grade moldings, shutters, mantles etc. out of it as well. Its an old favorite for lumber core and good grades of veneer core plywood. A good finisher can imitate alot of woods on it as well...a very versatile tree.
Post by: Jeff on June 08, 2002, 10:04:38 PM
An interesting fact about the largest of the tulip poplar is that they can no longer be polinated by Bees. Bees can only fly to a height of 40 or 50 feet. Two of this nations historic trees are the Tulip Poplars planted in 1785 by George Washington at Mount Vernon. They are now manually pollinating the individual flowers, one by one, relying on a lift bucket and Q-tips. Seeds can then be collected so the offspring of these trees can continue to be produced.
Post by: swampwhiteoak on June 09, 2002, 08:15:01 PM
I forgot about that Jeff.  The native pollinator is unknown, wonder what it is/was?
Post by: woodman on June 09, 2002, 08:28:01 PM
  I know where there is at leat 2 of them here in Mass. so big it takes 2 people to give them a hug.
Post by: Corley5 on June 09, 2002, 09:13:53 PM
Do hummingbirds like the flowers?  They'd be a pollinator if they do.  But will they fly higher than bees?
Post by: L. Wakefield on June 10, 2002, 06:50:22 PM
   I think henybees are the natural pollinator. I know tulip poplar honey is one of the types, and that tree is listed as bee fodder.   lw
Post by: swampwhiteoak on June 11, 2002, 02:27:07 PM
Honeybees are a pollinator, but they are european imports.  To my knowledge the native pollinator is unknown.
Post by: bjorn on June 13, 2002, 07:28:20 PM
Don,
Thanks for the info.  I have also been out of the loop for a while.  Busy with "real job" and milling when I can.  I got the info I need on Tulop Poplar span tables from a friend.  ANd yes, this is an Ag use building, thats what my permit says, and that's all it will be!  Amazing how difficult it is to use non-graded lumber without jumping through hoops like this!  Even if the quality is better than any of the crap you have to pay good money for.
Post by: Don P on June 28, 2002, 02:13:47 PM
I've been typing this up while out on site-offline...I see bjorn already found it but figured it might be worthwhile info for someone in the future. The book lists spans based on Fb and E and then goes on to give those values for quite a few species...a real good table to get hold of for those who might need something other than run of the (Canadian :D) mill info.
These are the design values for joists and rafters from the "92 CABO codebook NC Edition.
Yellow-Poplar (surfaced dry or surfaced green)
Select Structural 2x4 Fb 1700  Modulus of elasticity 1,500,000
No 1                              1450                                 1,500,000
No 2                              1200                                 1.3M
No 3                                675                                 1.2M
Stud                                675                                 1.2
Construction                    875                                  1.2
Standard                         500                                  1.2
Utility                              225                                  1.2
Sel Str 2x5&wider           1500                                  1.5
No1&appearance            1250                                  1.5
No 2                              1050                                  1.3
No3                                 600                                  1.2
Stud                                600                                  1.2
Allowable spans for floor joists...here are some examples this is from the table for 40 lb live load/10 lb dead load, deflection 1/360 span
2x6..E=1.3...16" on center...9'1"   Fb=1090
                   24"                  7'11" Fb=1250
       E=1.4   16"                  9'4"   Fb=1150
                   24"                  8'2"   Fb=1310
       E=1.5   16"                  9'6"   Fb=1200
                   24"                  8'4"   Fb=1380
2x8..E=1.3...16"                 12'0"  Fb=1090
                    24"                10'6"        1250
       E=1.4    16"                12'3"        1150
                    24"                10'9"        1310
       E=1.5    16"                12'7"        1200
                    24"                11'0"        1380
2x10..E=1.3...16"               15'3"         1090
                     24"               13'4"         1250
         E=1.4   16"               15'8"         1150
                     24"               13'8"         1310
         E=1.5   16"               16'0"         1200
                     24"               14'0"         1380
2x12..E=1.3...16"               18'7"         1090
                     24"               16'3"         1250
         E=1.4   16"               19'1"         1150
                     24"               16'8"         1310
         E=1.5   16"               19'6"         1200
                     24"               17'0"         1380
Rafters, allowable span for low or high slope 15lb dead, 30 lbs per square foot live load supporting gypsum ceiling deflection limited to 1/240 span (sorry but the only other choice was supporting plaster) Notice extreme fiber stress in bending rather than stiffness is the main factor in these tables
2x6...Fb=1000...16"           9'2"       E=.67
                        24"           7'6"           .54
        Fb=1200...16"           10'0"          .88
                        24"           8'2"           .72
        Fb=1400   16"           10'10"       1.10
                        24"           8'10"          .90
2x8   Fb=1000   16"          12'1"           .67
                        24"          9'10"           .54
        Fb=1200   16"          13'3"           .88
                        24"          10'10"         .72
        Fb=1400   16"          14'4"         1.10
                        24"          11'8"          .90
2x10  Fb=1000   16"         15'5"          .67
                         24"         12'7"          .54
         Fb=1200   16"         16'11"        .88
                         24"         13'9"         .72
         Fb=1400   16"         18'3"        1.10
                         24"         14'11"        .90
2x12  Fb=1000   16"         18'9"          .67
                         24"         15'4"          .54
         Fb=1200   16"         20'6"          .88
                         24"         16'9"         .72
         Fb=1400   16"         22'2"         1.10
                         24"        18'1"           .90
Post by: bjorn on July 01, 2002, 07:26:15 PM
Don,
That's all very helpful information.  I appreciate the effort.  This information does not seem to be readily available on the internet.
Bjorn
Post by: Jeff on July 02, 2002, 12:50:46 PM
It is now.  :)
Post by: Sawyerfortyish on July 28, 2002, 06:05:09 PM
Better late than never I guess. ::)Im in north jersey and we got lots of big poplar I cut one a year ago two ledges farther than I could get the skidder to  dropped it towards the skidder  no problem at 96' it was still 14" on the little end and I had 75' of cable. It was all the old 230 timberjack wanted to do to move it with the winch :o had to cut it in 3 sections to get it out. I sawed another on the mill that made the rear wheels on my payloader come off the ground  ???an 8' log I got almost 700' of lumber out of! :)The poplar here grows big and tall :D ;)
Post by: Mitchell on October 20, 2018, 06:20:42 PM
Quote from: Don P on June 03, 2002, 11:30:37 AM
Don P'Im from southwest va and wanted to know if board and batten Poplar would be good for siding for cabin off the ground and on a foundation of block with plastic on ground inside the foundation of block to keep moisture down, built houses on foundations on other houses and worked very well.Been a carpenter for 30 years and wanted your opinion about board and batten for a cabin 16x24.might have to build other sections but anybody have a preference on boars width? Thinking 8" wide or 6" wide if I can
Post by: Don P on October 20, 2018, 07:22:01 PM
Hey Mitchell, you dug up an old thread I had forgotten about :). Whereabouts are you, I'm in Grayson County.
Poplar was the main clapboard siding wood here in the past, most I've measured seems to be 5/8x6" in that style. It would be fine for board and batten. I like ~10" wide with ~3" battens but the wider you go the more cupping gets to be an issue between sawing and hanging it. Board and board is another popular style, for 6 and 8", the 8" boards would be on the back layer spaced 4" apart by using small 4" x framing width and siding thickness blocks, then the 6" would go on the outer layer overlapping the 8's by an inch on each side so in the finished product it all looks like 6". I usually borate poplar, powderpost beetles like the sapwood.
This is a pic of how I like to do the bottom of B&B, this is hemlock but could be poplar, I do like being further above grade! The bottom horizontal board has a 15 degree bevel ripped on its top edge and the boards have a 15* on their bottoms then the battens extend to the bottom of that horizontal board. This blocks the critter crack and helps shed any water that tries to creep into that joint.
(https://forestryforum.com/gallery/albums/userpics/10017/BnBskirt.jpg?easyrotate_cache=1482933608)
To round out more on this thread about big poplars, which with the Chestnuts gone it is now the largest tree in the eastern forest, Most of this barn is poplar logs 20-30' long, the top plate beams are 60' long 12x12's
(https://forestryforum.com/gallery/albums/userpics/10017/1stshed.jpg?easyrotate_cache=1500418378)
