LT70 Speed Control Wide Open
Started by Cypress Man, September 28, 2022, 08:18:30 PM
Cypress Man
My 2013 LT70 WIDE has intermittent head speed issues. While the head is moving forward it will suddenly speed wide open. After discussing with WM Indy, we changed the variable resistor speed control, swapped the joy sticks, and  replaced the communication wire on the festoon cable with no improvement. Anyone know what else to try. What else can cause this to happen?
LT70 wide head electric, IC5 Power conveyor, transfer table, Stop and Load Log Deck, Catapiller 360B Telehandler, Cat tl642c Teleloader, Cat TH514 Telehandler, Woodmizer EG400 edger, Logosol PH360 moulder, Extrema 26" Planner, Grizzly 16" dual conveyor resaw, Prentice 285 log loader
Southside
Is this a Super 70? If so have you checked the hydraulic valve that regulates the head drive motor?
White Oak Meadows
Cypress Man
No. Its not a super 70. Its DCS (Direct Control System) All electric. 3 phase 25hp motor and single phase hydraulics
Southside
What is the drive motor powered by? Perhaps @customsawyer can help.
White Oak Meadows
customsawyer
I'm not up to speed on the DCS mills. Is the drive motor 12 volt? Maybe Gary @gmmills  can chime in.
www.thecustomsawyer.com
NickParsons
Does your mill have the Diesel engine or electric motor? Is it only in forward? Have you checked the blue and green wires leading to the feed motor for a spot where they are rubbed through to ground?
-Nick
ladylake
 Did you get it fixed yet, the wire rubbing together theory sounded good.  Steve
