Author Topic: white pine and apple tree compadiability  (Read 1053 times)
Offline Hotrod RLC
« on: March 16, 2022, 07:24:32 PM »
 i have a full grown apple tree in my yard that i have kept pruned and trimed over the years .tree will bloom but not bear apples . i know it needs poliniating and i have several other apple trees aprox two hundred feet from this one . now question is , their is a big white pine tree that shades the apple tree in the afternoon and all the sun the apple tree gets is in the morning  is this white pine the cause of the tree not producing apples  please advise if so i got a chain saw  :P 8)
Offline GAB
Re: white pine and apple tree compadiability
« Reply #1 on: March 16, 2022, 08:10:36 PM »
Would just trimming branches off of the pine tree get the apple tree more sunshine?
GAB
Offline Menagerie-Manor
« Reply #2 on: March 16, 2022, 08:50:55 PM »
Had about a dozen antique apple trees on my first property and while they did bear some fruit it wasn't until I got aggressive with trimming that they really woke up.. Got out there when the leaves dropped and really took off a lot of the upper growth opening up everything. Following spring they literally exploded.
If you come to a fork in the road take it.....
Woodland Mills HM126
Yanmar YM2310D
Stihl 031AV
Stihl MS251
Offline Southside
    • White Oak Meadows
« Reply #3 on: March 16, 2022, 11:44:44 PM »
You should be getting pineapples from the sounds of it.   :D
White Oak Meadows
Offline Hotrod RLC
« Reply #4 on: March 17, 2022, 02:45:51 PM »
 pineapples would be nice / i know walnut trees cause problems to other type vegitation because of chemical reaction / though pine might not like apple  trees  the limbs touch and are lined up so apple tree gets wind through pine tree . took chain saw and pruners and worked on apple tree . told if it did not start producing i was gonna cut it down // it did not listen  :D 8)
Offline chep
« Reply #5 on: March 17, 2022, 10:17:34 PM »
Cut down the pine. Wait 1  year. Prune the apple tree. If you want apples its prob not going to happen under the pine.
Offline peakbagger
« Reply #6 on: March 18, 2022, 06:10:22 AM »
There is a good chance that you need to get your soil analyzed and the soil amended. Get the PH right and then you may need to add calcium and potassium as wel as regular fertilizer.
Offline newoodguy78
« Reply #7 on: March 20, 2022, 09:38:48 PM »
I agree with what youre saying. You think its the shade or how the pine needles are effecting the soil thats the main issue? Combination?
Offline Hotrod RLC
« Reply #8 on: March 20, 2022, 10:52:18 PM »
in discussing the pine tree and apple tree which is located in our front yard with my wife i have encounted a slight problem /// wife stated we are not cutting pine tree // blooms on apple tree with no apples is what i get  or start chain saw and move to barn in hay loft any suggestions  :D
Offline Southside
    • White Oak Meadows
« Reply #9 on: March 20, 2022, 11:17:00 PM »
You might want to insulate the hay loft first.   :D
White Oak Meadows
Offline SwampDonkey
  • Large Tooth
« Reply #10 on: March 21, 2022, 05:12:12 AM »
The pine maybe shading the apple, which inhibits blossom development. Apples need full sun. You'll see this on old field, a big old wolf spruce standing there, and an apple seeded under it, it grows 30-45 degrees off vertical and the limbs out in the sun get blossoms and apples.
No amount of belief makes something a fact. James Randi
Offline Prizl tha Chizl
« Reply #11 on: April 21, 2022, 02:58:17 AM »
Id say it was the soil more than the shade. If youve got a half day of direct sun you should be getting a decent crop, all other things being favorable. Unfortunately its a lot of work to undo what a mature pine can do for the PH. We cut down a spruce 5 or 6 years ago that was shading an apple-as well as our house in the winter. It still hardly makes a crop and Ive added quite a bit of ashes and compost underneath. If we dont get a good o this year, Im thinking of cutting down the Apple too, and putting blueberries there. Where would you sleep if you tried this approach?🐶
Are they blooming at the same time? Apples pollinate pretty easy at that distance, but with plums Ive had to set a bucket full of blossom covered branches under the tree to get a full crop before, something you might try as a way to investigate.
The Woods Is My Church
Transplanting White Pine tree?
Started by WhitePines on Ask The Forester
Last post December 02, 2013, 06:17:25 PM
by Jeff
New Tree Spacing? White Pine Saplings
Started by semologger on Tree, Plant and Wood I.D.
Last post May 11, 2008, 07:01:26 PM
by SwampDonkey
Under the old apple tree
Started by Don P on The Outdoor Board
Last post August 12, 2020, 03:42:32 PM
by mike_belben
apple tree problem
Started by L. Wakefield on Ask The Forester
Last post September 07, 2004, 12:37:44 AM
by EquineGuy
