Author Topic: Some type of Hickory?  (Read 752 times)
Offline Poquo
« on: May 05, 2022, 08:28:10 PM »
Cut this log today, very hard wood cut like Pecan. If I went to fast the cut would be wavy and the sawdust was fine even with new blade. All I have to go by was the log no leaves or limbs were on it.
2015 Woodmizer LT40HD26
Offline WDH
  • Board Moderator
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: Some type of Hickory?
« Reply #1 on: May 05, 2022, 08:28:57 PM »
Yes, hickory.
Offline Poquo
« Reply #2 on: May 05, 2022, 08:47:05 PM »
Thanks, WDH the bark on this one threw me off.
Offline B.C.C. Lapp
  • I'd rather be logging.
« Reply #3 on: May 06, 2022, 02:55:05 PM »
Round here that is referred to as "pig" hickory. Ive no idea why.
I do know that its every bit as hard as shag bark hickory and on a cloudy day you can see sparks coming off your saw chain when you start your cut.   When I had my band mill I really didnt like sawing the stuff.   I'd be changing bands all day.
Listen, or your tongue will make you deaf.
Online beenthere
« Reply #4 on: May 06, 2022, 03:17:22 PM »
Maybe pignut hickory (Carya glabra)
Offline Poquo
« Reply #5 on: May 06, 2022, 07:22:37 PM »
Thanks for the replies, it was a pain to cut I guess it's in the smiley_devil wood family tree.
Offline WDH
  • Board Moderator
« Reply #6 on: May 06, 2022, 08:32:45 PM »
Actually on the Janka Hardness Scale, pignut hickory is a good bit harder than shagbark hickory.
Janka Hardness of North American Hardwoods in Drying and Processing
Shagbark hickory has a Janka Hardness of 1880 while pignut has a Janka Hardness of 2140.
Offline Poquo
« Reply #7 on: May 06, 2022, 08:59:04 PM »
It was the hardest log I've cut so far. It was worse than Pecan.
Online moodnacreek
  • Sawin by the notches
« Reply #8 on: May 10, 2022, 09:05:16 PM »
Looks like white heart hickory. The bark is harder than the wood they say.
3 sided husk on hickory nut - what type of hickory is it?
Started by Lanier_Lurker on Tree, Plant and Wood I.D.
Last post August 25, 2007, 09:18:14 AM
by Lanier_Lurker
Hickory? If so, what type?
Started by Old Greenhorn on Ask The Forester
Last post September 22, 2021, 04:20:07 PM
by kantuckid
what type of blades do you use when cutting hickory?
Started by milling man on Sawmills and Milling
Last post July 15, 2008, 12:15:39 PM
by Bibbyman
Winch-line Hook, ring type vs. sleeve type
Started by CuddleBugFirewood on Forestry and Logging
Last post March 23, 2013, 12:25:58 PM
by lumberjack48
