Author Topic: Solar and batteries, my .02  (Read 4897 times)
Offline Klunker
Re: Solar and batteries, my .02
« Reply #20 on: April 29, 2020, 12:11:25 PM »
Mapleflats, we just had another power outage last week. 3 hours without power.
Not a big deal, if we didn't have the batteries not much would of been different.
Happened at night. Our grid supply alarm went off to advise us.
I think we get about 2-3 power outages/year. Usually a couple of hours only.
We had issues with our solar system. I noticed that when our panels were partially covered by snow we would get zero output. We had approx 40% open and clear but still no power generation.
Turns out the system was setup improperly in the beginning. Grounding issues. While working on it the Tech was on the phone with the mfg. The Tech changed the way it was grounded as advised by the Mfg. When he turned the power back on the wiring from the panels started to melt the insulation which quickly tuned to smoke and fire. At this point the Tech was smart enough to run to the disconnect for the solar panels and shut them off. Ended up replacing the Breaker box that is fed from the panels and a big chunk of wiring.
Now we have more production, looks like our power from the grid will be about 1/3 less.
We still have maybe 6 years or more on our existing lead acid batteries before replacement. I'm hoping there is something much better out there then.
Offline nativewolf
« Reply #21 on: June 03, 2020, 04:59:40 AM »
1 or even 2 powerwalls would do wonders for you, sorry to hear about the install issues.
Liking Walnut
Offline maple flats
  • Life is what you make it!
    • cnymaple.com
« Reply #22 on: June 07, 2020, 11:52:08 AM »
Klunker, I can tell you one thing from experience. LiFePo4 batteries are a great choice but only with a few must haves. 1st, the battery management system (BMS) must have a shut down capability to prevent trying to charge the batteries when below freezing. My big mistake was believing a Chinese manufacturer and not testing it. I complained with no success (China). Or the battery bank must be in a space that does not freeze. In my case my battery bank was in my unheated sugarhouse and I did not go to the sugarhouse for 6 days in which time the solar panels were covered with snow and I had a heat pad to keep the batteries warm. The batteries were in an insulated box. My problem turned out to be stupidity, I connected the 65 watt heat pad directly to the battery bank and thus it did not shut down when the bank got to the low voltage setting. Hind sight is 20/20. I should have built a shelf and placed the battery bank in my tiny heated room (2.5' x 5.5' x6' with 3" foam insulation), but that would have required running the heavy battery cables about 45' and being that long I'd have needed bigger cable, instead of 4/0 they would have needed to be 350MCL to minimize voltage drop. I now know two things, placing the battery bank in the heated space and paying the cost for the heavier cable would have been cheaper than wasting $2500 on what ended up being scrap batteries.
I'm still thinking about how to start up that portion of my electric system. I have a XW6048 inverter (6000 watts @ 48V) which when purchased 12 yrs ago cost $3400. It's a good inverter for battery only or battery+ grid tie net metered, but will not grid tie without a 48V battery bank. As I see it now I have to decide, do I want to go back to a Trojan 48V 240 AH lead acid bank and have the monthly servicing (my last bank worked for 10.5 years) or do I want to buy a different inverter and sell the XW6048 one? Inverters are less expensive now and being that array is only 1480 rated watts, I could get a 2000 watt or maybe even a 1500 watt grid tie inverter and forget the battery back up, since that was only a back up for a propane heater to keep my reverse osmosis machine from freezing and since I use a propane wall furnace to heat it which needs no electric and the fact that in the 8 years since I added the grid connection I have never had a power outage. I need to make a decision in the next month or 2.
Offline scsmith42
    • Whispering Pines Farm
« Reply #23 on: June 07, 2020, 03:00:52 PM »
Klunker, it seems to me that if you simply add a generator / battery charger combination to your existing setup, you can minimize additional cost yet extend your time off grid.
Run the generator in the late afternoons to fully charge up the battery bank before bed, and then run off the batteries overnight, and part of the next day until you need to fire up the generator and recharge.
If you're able to buy a propane generator, you will have the most maintenance free system possible.  The problem with gasoline and diesel generators (I have ten here on the farm) is that the fuel will go bad in you don't keep it somewhat fresh, and the filters on the diesel units will clog up in the winter time.
Tom's 3638D Baker band mill
Offline maple flats
    • cnymaple.com
« Reply #24 on: February 08, 2021, 11:29:03 AM »
At my sugarhouse I had a diesel generator to supplement my solar. I used that for 3 years, I never had any filter clogging or starting issues. I do use a product called Power Service year round, it gets added to my large tank at every fuel delivery. For the first year using that generator I used Stanadyne diesel fuel additive, no issue then either, but I switched to the Power Service only because it was easier to get locally.
Aluminum can solar heater or thermal mass storage? Solar klin
Started by Doug_D on Drying and Processing
Last post May 12, 2010, 10:06:57 AM
by Den Socling
Mental Exercise! Hybrid kiln design (solar drying concept w/o solar heat)
Started by scsmith42 on Drying and Processing
Last post March 31, 2016, 10:51:46 PM
by GeneWengert-WoodDoc
batteries
Started by woodmills1 on General Board
Last post February 04, 2013, 10:49:55 PM
by Brucer
new batteries
Started by treechopper40 on Forestry and Logging
Last post February 03, 2014, 07:49:24 PM
by Maine logger88
