I'm sure the leaves do suck some moisture out but I'd just get it cut split and stacked in the sun as quick as possible. That works best.
I heard a story, maybe a legend🤔 of Canadians to the north of here dropping paper birch, and then running a kerf the length of the tree with a chainsaw. The bark would curl away from the cut and let the wood dry. Never tried it myself, but I've seen the same effect of harvester cut birch logs. The feed rollers can chew the bark up enough that it will split open, the moisture content is noticeably lower on those sticks than with ones that have intact bark.
Started by Sawdust Lover on Drying and Processing
Started by PAmizerman on Drying and Processing
Started by malignity on Drying and Processing
Started by trapper on Firewood and Wood Heating
