Why you clean it out?How due the Heat exchangers in the back look?
In my experience, less dry wood will lead to poor reaction chamber performance. A good bed of hot coals will help.
soda cans
In fire tests conducted on aluminum materials, it was found that when fire temperatures exceed the melting point (which occurs at a range of 600-660°C), aluminum surfaces that are exposed to the fire can melt, but do not burn. Heating the cans causes an increase in heat in a chimney which can help prevent creosote from building up on a clean chimney. However, aluminum oxides are very stable and do not react to high temperature. This means that there will not be much of an impact on built-up creosote.
What is your conclusion about reason your creosote build-up happens so quickly? My guess is wood too wet.
Started by chet on Alternative methods and solutions
Started by sublime68charger on Firewood and Wood Heating
Started by Logging logginglogging on Firewood and Wood Heating
Started by DDW_OR on Firewood and Wood Heating
