Galtech motor16CC displacementFlange SAE-A 2-Bolt MountUni-DirectionalShaft 3/4 Key Length 2-1/8. With outboard bearingSAE-12 x SAE-10 ORB PortsInternal Drain
I don't know what your assembly looks like, or if this would fit, but Parker F11 motors are available. The F11 is a series of motor available in different displacements.3707249 PARKER ? SPThere are a few very knowledgeable hydraulic guys on here. @fluidpowerpro ?
Did a little detective work and best I can tell is that motor is an old Webster unit that has been discontinued. Its an external gear motor so it should be pretty standard. If you know the displacement and match the other specs, a motor from another manufacturer should work. The Parker F11 will work too but that is a bent axis piston motor which is high perf compared to an external gear motor. A lot more costly and you will need to add a case drain line. I did see a company called Legacy Hydraulics that says they have direct replacements for the Webster unit.You might want to give them a call. 331-200-5011.
Started by logloper on Firewood and Wood Heating
Started by gunman63 on Forestry and Logging
Started by GRANITEstateMP on Firewood and Wood Heating
Started by just_sawing on Forestry and Logging
