Do you think the water to air heat exchanger will get hot enough to damage the air conditioning coils plastic condensing tray? It’s one of those units with the plastic drip tray.
Are they below the a coil with spacing or is the heat exchanger touching the a coil? I’ve seen them installed like that. A friend of mine has the central 5036 boiler and the heat exchanger is mounted in the plenum directly below the a coil, but it looks like there is 2-3” of spacing between the exchanger and a coil.
will be posting what i do and what i should Not do.
I'd spray some diesel down the exchanger and light it up, blow air through it with a leaf blower. Rather than scraping it off.
Started by Logging logginglogging on Firewood and Wood Heating
Started by DDW_OR on Firewood and Wood Heating
Started by talldog on Firewood and Wood Heating
