Author Topic: Privacy fence rails 2x4 vs 2x6  (Read 329 times)
Offline Sedgehammer
  • Old enough to know better, but ya only live once!
« on: October 04, 2021, 09:36:51 PM »
puttin up a privacy fence on the one side of our property facing the road. 1x12x8 syp for the panels. will have a top 2x4 for trim along with a 2x4 under it facing the road. my fence guy electrician friend is telling me the 2x6 rails will sag before the 2x4 rails will. Posts will be 8' OC. i'll support the middle of the rails with a brace while the rails air dry. This is going along a stem wall, so i can brace off of the stem wall to under the 2nd rail from the bottom
I can't find anything on the interwebs, so thought I'd ask here.
Online trimguy
Re: Privacy fence rails 2x4 vs 2x6
« Reply #1 on: October 04, 2021, 09:52:24 PM »
That doesn’t make any sense to me, but interested in what others have to say.
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #2 on: October 04, 2021, 10:02:07 PM »
  Not sure about the sag (Hard to believe 2X6 would sag worse than 2X4) but be sure to check wind conditions in the area. Privacy fences have a bad habit of blowing over if not massively braced in some areas and I heard Oklahoma has a rep for wind.
Offline Sedgehammer
« Reply #3 on: October 05, 2021, 12:11:18 AM »
That's what I said
Yup, windy enough here. I think we have that under control. There are corners and if necessary i can put eye bolts with turn buckles from the posts to the stem wall
Offline 69bronco
« Reply #4 on: October 05, 2021, 05:48:39 AM »
Just did a similar fence, 1x16ish(live edge)x8' tall. I used full 2x6 for top and bott rails and 2x4 in middle. I put a diagonal brace on the back side between posts from top to bottom rail to cure any sag. Seems to be very stable.
Offline Sedgehammer
« Reply #5 on: October 05, 2021, 08:30:21 AM »
@69bronco bingo
« Reply #6 on: October 05, 2021, 09:43:00 AM »
   Saudi Arabia has not adopted our "Adopt a Mile" program and are not, as a society, overly concerned about litter. (Some TCN will clean it up later is their attitude.) It is not uncommon to have a Shammal (a very strong wind/sand storm) and so many plastic bags (What we always referred to as the Saudi National Bird) will blow up against long, strongly built chain link fences that they catch so much wind they actually blow the fences over.
Privacy fence
Started by bigred1951 on General Board
Last post May 01, 2019, 12:31:32 PM
by RPF2509
Privacy Fence Ideas using green SYP
Started by Kipper on Sawmills and Milling
Last post February 25, 2016, 08:20:35 AM
by mmartone
Making holes in fence posts for the rails, looking for ideas
Started by plasticweld on Sawmills and Milling
Last post June 10, 2015, 02:54:04 PM
by LittleJohn
Would 4x4 reclaimed fence rails be suitable to frame a small extension??
Started by fallenoak on Timber Framing/Log construction
Last post February 12, 2016, 09:04:36 AM
by fallenoak
