New blade issue
Started by TroyC, October 16, 2021, 07:53:10 AM
TroyC
Put a new Timberwolf on the EZ 40 yesterday to finish off a cedar slab. Made a skim cut and saw one tooth was leaving a really deep trail about every quarter inch. First time I had a new blade with a tooth that far out. Put my resharp back on and finished with smooth cut. I am careful handling blades so I don't think I bent it.
I've used about 8 blades out of 15 I bought with the mill. I don't have a setter ( yeah, I know) so I just sharpen a few times and retire the blade. I'm a hobby Sawyer so it's not really worth the setter. Cost of a setter would buy me a lifetime of new blades.
I'm just wondering how often new blades are out of set that bad. Hopefully this was a one in a hundred thing.
ladylake
 Just find the bent tooth and bend it back, stuff happens.  Steve
Well, if this was me, I'd much sooner bet that I did something in one of my many moments of in attentiveness that snagged a tooth. That would bring the odds down from 1 in a hundred to almost even.  What Ladylake says.
Southside
Cedar is notorious for hiding sand, rocks, tools, and missing children in the bark inseams.  It's quite possible you hit something just as the band entered the log.
White Oak Meadows
SawyerTed
A tooth that far out should be easy to see.  A piece of 3/4" or 1" flat bar with a notch in the end makes a good tooth adjuster.  The notch can be cut with a 4" grinder with a cut off wheel.  The notch only needs to be 1/4" to 3/8" long and 1/16" wide. Pliers work but I don't find them as easy to make fine adjustments.
TroyC
If I hit something it was at the beginning of the cut.
I read somewhere on the Forum about a set checker. Any quick ideas on checking blade on saw? I tried to find wayward tooth but was not successful.
LeeB
A digital caliper can be had cheap enough.
maple flats
The marks it left, were they lower or higher than the rest of the face? If lower, look for the culprit  in that direction on the band, if it was higher look on the top.
maple flats
Even a basic tooth setter will do the job, even flea bay has some for under $40, but you could study them and make one for even less.
ladylake
  If it's that nasty you should be able to see the bent tooth by holding it up to the light. To get marks every 1/4" you'd have to be sawing really slow.  Steve
YellowHammer
Leave the band on the mill, get an adjustable wrench like a crescent, tighten it to where it just clears the correctly set teeth and drag it down the band.  When it hits the over set tooth, it will tell you.  Then put the tooth in the wrench jaws and tweak it straight.  Very easy, very fast, very common.  Or just use the gap in the jaws as a tooth set checker.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Stephen1
I will drag the band through my fingers backwards and can usually feel when there is 1 that far out.
TroyC
Thanks everybody! Will do the crescent trick tonight. The bad tooth cut downward into the cant. I didn't take a lot of time to find it, just changed blade out. First new blade I had act that way.
kelLOGg
Here's what I use to straighten teeth.
LeeB
The cresent wrench idea is pretty good. I'll have to remember that one. I would think you would need a better quality one to avoid slop.
customsawyer
If you can't find it bring it by the mill and we will find it together. Call first as I'm going to Moultrie one day this week.
www.thecustomsawyer.com
SawyerTed
Thread hijack! Moultrie as in the lake?
JoshNZ
Quote from: LeeB on October 17, 2021, 10:20:08 AM
That's what I thought, most of my crescents have a bit of slop. I'm looking forward to trying this, Ive never been able to find a rogue tooth by feel.
btulloh
I've found that a metric crescent wrench doesn't work as well as an SAE crescent wrench for this.
HM126
LeeB
Southside
Thought you had a bum knee?  :D
White Oak Meadows
SawyerTed
Trying to live vicariously!  :D
customsawyer
Moultrie is the name of a town in GA. where they host a annual Ag. show. It will go on Tue., Wed., and Thur. this week. It has always been hosted in the middle of the week. Rumor is that they started it in the middle of the week so the farmers could get out there and see what they needed to see without tripping on the city folks getting in their way. They will have everything for cooking stuff to work dog shows, to plowing and haying demos. Plus sawmills, wood splitters and logging equipment. Before covid you couldn't see it all in three days. Not sure how it is going to be this year. Used to be a group from the forum that would meet up down there and camp.
caveman
It has been a long time since I've attended the Moultrie AG Expo.  Years ago, we would leave school at 3:30 or 4:00 in the morning with our ag kids loaded in a bus and spend the day up there looking at everything.  It was phenomenal and also made for a long day.
Caveman
SawyerTed
I got excited about the possibility of Lake Moultrie in SC!   :D  Later it dawned on me that Moultrie is also a town in Ga. duh!  ::)
The Richmond, Va. East Coast Sawmill and Logging Expo was about one third of what it usually is.
