Author Topic: Should I be upset by this purchase?  (Read 1522 times)
Offline SleepyDog
« on: June 22, 2022, 08:01:19 PM »
Recently bought a hand forged draw knife.
$159 total with leather sheath, shipping, and taxes.
Beveled edge varies and cutting edge is not straight. My first foray into buying direct from a blacksmith but I feel like this is not what should be expected. Thanks in advance.
Offline barbender
Re: Should I be upset by this purchase?
« Reply #1 on: June 22, 2022, 11:01:32 PM »
Well personally if I was a blacksmith and produced that, I'd be ashamed of myself. Back when I was peeling logs, I bought a Barr draw knife. Excellent quality, awesome steel and just an overall pleasure to use. If I tried using your's to peel logs it would likely get chucked in the woods, those valleys in the blade would make it very difficult to get a smooth cut. Said another way, if I made the edge on my Barr drawknife look like that I would be just sick over it. I hope they take it back and make it right.
Offline rusticretreater
  • I finally have enough wood!
« Reply #2 on: June 22, 2022, 11:20:57 PM »
You should be disgruntled to say the least.
Kubota BX25
Homemade Log Arch
Husqvarna 562xp
Offline kantuckid
« Reply #3 on: June 23, 2022, 06:42:25 AM »
I have three drawknifes, one is a family heirloom blacksmith made version with a slightly arcing blade by design. It's also leaps and bounds the best for peeling pine logs shaving horse duty. The handles angle away from the work so easier to negotiate around pine branch stubs. It will easily shear clean a pine branch stub for appearance when sharp. It's hard enough to stay razor sharp for long hours of use. The other two I bought at sales cheap but they are high quality knives and work great. I have a "thing" for drawknifes.  :D
That knife above can be brought to a continuous edge with care, but perhaps the price point isn't seen in the workmanship but if seriously sharp and good steel it will work fine for bark, a bit less so for something like shaving actual furniture parts-such as a chair rung. I'd use it if your sort of stuck with it and move on.
I suspect there's lots of wanna be blacksmiths (some good, better and best types ;D) in todays world where many knife makers and old time arts & crafts pursuits.
Offline Old Greenhorn
    • Woodsman Forest Products
« Reply #4 on: June 23, 2022, 07:16:44 AM »
I would contact him directly and immediately. There is a difference between "not being made well" and "being made poorly". What you have was made poorly. His blade shaping and finishing work is quite poor and not ready for public sale. That looks fixable, but there are spots where a lot of material will have to come off and it may require some touch up heat treat work in those areas depending on how he does the re-shaping. The heat treat temper must be consistent across the cutting edge to ensure a long life of sharpening and the tempering and avoid hot or cold (hard or soft) spots must be consistent. He either rushed his final grinds or didn't look at it very closely because he was doing batch work and in a hurry. He may not have the proper machine to put that grind on and used a comprise method. The right grinder (with the right hands) would have at least put a consistent cutting edge on it easily, even if the back taper was a little off. That leads me to think it is an issue of skill level.
 This is just my opinion, you asked. Also, if I were sending it back I would do some careful checking to make sure those handles are secured properly. On a draw knife, because of how it is used, this is critical and you don't want a failure down the road. If his blade looks like that, it would make me suspicious of the handles. That's just me.
 I can't make decent blades. It takes a lot of skill and knowledge. I have some of the knowledge and a little of the skill, but not enough. I have a lot of respect for any person that can do it and awe for those who do it well.
 I wish you the best of luck. Please let us know what transpires.
Oscar 328 Band Mill, Husky 450, 562, & 372 (Clone), Mule 3010, and too many hand tools. :) Retired and trying to make a living to stay that way. NYLT Certified.
OK, maybe I am the woodcutter now.
I can work with wood, but I am NOT a Woodworker, but almost.
Offline Don P
    • Calculator Index
« Reply #5 on: June 23, 2022, 07:24:02 AM »
That's the first thing I saw, I'm not seeing a peened button on the end of the handle. A handle simply driven on a tang won't hold up to the heavy use a drawknife sees. If he is new it might be an opportunity to work with him to develop his skills.
The future is a foreign country, they will do things differently there - Simon Winchester
Offline kantuckid
« Reply #6 on: June 23, 2022, 08:35:21 AM »
My best one is blacksmith made, has inlaid edge, hand turned walnut handles with sharp spike handles peened over brass washers. My other two are older items, beyond 50 years IMO, and have peened handles but bit less hand crafted from a factory that's no longer there.
The arc of the blade or straight depending on intended uses, plus the angles of handles all makes for a good tool. The angle is a special aspect as it's not only offset away from the blade the angle of attack is built into the knife as well. Far more complicated tool that at first glance.
« Reply #7 on: June 23, 2022, 09:27:25 AM »
That's the first thing I saw, I'm not seeing a peened button on the end of the handle....
Yeah Don, I didn't elucidate, but I am 95% sure (maybe more) that those are standard file handles with a driving fit. I buy those buy the box of a dozen fairly cheap. They are made for a friction (drive on) fit and are loaded on the push stroke. They work perfect for that. But a draw knife is of course a pull stroke and that's why the decent knives have a through tang with a washer or cap and a peened over end. If you are really hauling on that knife and 'in the zone' and a handle slips off you could get hurt in a memorable way.
Offline SleepyDog
« Reply #8 on: June 23, 2022, 12:13:57 PM »
Thank you everyone. That was what I was thinking and when I had reached out to him, very politely, he got defensive and passive aggressive, saying I should shop at Home Depot, etc. since I am unable to appreciate the work of a blacksmith. I do not think he is one to take constructive criticism.
This was on ETSY I'll try another vendor or site. Any suggestions? I would still like to support an independent blacksmith or at least a small shop making these handmade.
Thanks in advance!
Offline Tom King
    • HistoricHousePreservation
« Reply #9 on: June 23, 2022, 12:17:49 PM »
My Father had a saying, "When you have a snake by the tail, the best thing you can do is let him go."  I hope you can get your money back.
There is a guy that sells refurbished old ones in the Classified section on the woodworking forums Sawmillcreek.  He does a good job.  He doesn't put them up very often, and they go fast.  I've bought a couple from him.
All mine are old ones that work great.  A piece of vinyl siding undersill trim makes a good edge protector.   I got that idea from the seller mentioned above.
Offline Lostinmn
  • I was me, but now he's gone.
« Reply #10 on: June 23, 2022, 01:34:31 PM »
I have been very happy with my barr timber framing tools.
If I was in the market for a draw knife, its where I would start!
Offline barbender
« Reply #11 on: June 23, 2022, 01:53:35 PM »
Yep I mentioned Barr as well. I would imagine one of his drawknives is upwards of $200 now. Worth every penny, though. I don't know if he has a smaller version, but the one I have is made for peeling logs. It is big, heavy, and used with the bevel down. It would be too big for smaller work.
Offline barbender
« Reply #12 on: June 23, 2022, 01:56:06 PM »
Offline kantuckid
« Reply #13 on: June 23, 2022, 04:52:24 PM »
Yikes! I'll suggest ebay or a fleamarket antique tool dealer. They are on wide spots in the road in my part of KY. A serious drawknife isn't easy to find but no need to pay hundreds of dollars unless your a tool freak. Maybe I need to sell a few hundred dollars of the ones I never use?  :D
Details aside, the drawknife we see in this thread is going to cut well if it's sharp and made of good steel. Why do you need a sheath for a drawknife?
When I ran a trapline out in KS a hatchet sheath was essential, but with a drawknife I simply lay it aside when I move my workpiece.
How was this to be used? like I said, if bark removal it should be fine but honestly a fleamarket drawknife for $25 would do that just fine.
Offline Brad_bb
« Reply #14 on: June 23, 2022, 08:11:54 PM »
I paid $75 for a sheath for my draw knife.  You don't show yours so I don't know if it's basic or well done.  That leaves $84.  How many hours does it take to make a draw knife (a good one)?  What rate is reasonable for a blacksmith?  If his time is worth only $40/hr, that 4 hours to make a draw knife, make a sheath, make handles, Sharpen the tool, install the handles.  To do it right by hand, it would cost a lot more than $159 and take a lot more than 4 hours.
Lastly, I'd want to try the tool and know how it works.  You typically use only a small area of the knife when you draw.  It's not a chisel where you need a straight edge.  How does it work?
Offline cib
« Reply #15 on: June 24, 2022, 08:19:39 AM »
That is poor quality work. I'd take it back to the smith and ask if he would make it right. As a smith I couldn't imagine letting that leave my shop. There are a lot of good smiths out there now and some that simply don't have the quality control on their work unfortunately.
« Reply #16 on: June 24, 2022, 08:34:24 AM »
I think one of the clues here is the appearance of the name "Etsy". I don't think of this as a traditional outlet for journeyed craftsmen. I think of it as a hobbyist/side job/ extra income outlet.
 Probably your guy here watches 'forged in fire' on TV, read a few books, talked to a few folks, and just like many of us in sawmilling, he is learning as he goes. Nothing wrong with that, but he is not quite a bladesmith yet and he should drop the attitude down a bit and unknot his panties.  ;D
 I'd just send it back for a refund and let him look it over again while you find what you want. I guarantee he will re-do that edge when he gets it back. :D If he doesn't he won't last long at all.
Online Jeff
  • Fearless Leader
  • Oh la di oh la da
    • Behind the  Forestry Forum YouTube channel
« Reply #17 on: June 24, 2022, 03:59:31 PM »
Send him a link to this topic.  :D
Offline customsawyer
    • The Custom Sawyer
« Reply #18 on: June 24, 2022, 04:48:42 PM »
It would be interesting to know if it is hardened its entire length. I'm not suggesting you test it as I'm sure that is all the excuse he would need to not take it back. If he is worth his salt he will be ashamed of this work somewhere down the road. That is doubtful if he is as defensive as you say.
Two LT70s, Nyle L200 kiln, 4 head planer, 30" double surface planer, Lucus dedicated slaber, Slabmizer, and enough rolling stock and chainsaws to keep it all running.
www.thecustomsawyer.com
Offline kantuckid
« Reply #19 on: June 24, 2022, 05:08:10 PM »
I'll beg to differ on how much of the blade you'll use. Depends on the use at hand. Yes, I have used one for hours on end and to remove bark, it helps the job/cut to draw at an angle and slide the length of the blade through a swath of bark. Thats not true if the purpose is a wood part thats narrow.
I've never heard the intended use as yet?
To fault the guy for using Etsy is off target. How do we know how adept he is at locating the best domain to sell. Either send it back or keep it, whichever is your happy place. It's not the best workmanship but it is what it is. :D
Special orders don't upset us
Started by bandmiller2 on Sawmills and Milling
Last post August 28, 2012, 08:04:48 PM
by bandmiller2
Orange Bowl Upset
Started by bugdust on General Board
Last post January 21, 2012, 11:54:08 AM
by POSTON WIDEHEAD
First Purchase
Started by LazarusKnudson on Chainsaws
Last post December 07, 2016, 09:19:06 AM
by HolmenTree
please help on atv purchase.
Started by mountaineer on General Board
Last post October 06, 2009, 02:03:12 PM
by caver
