Author Topic: Tie strap kit help for 404 chain  (Read 370 times)
Offline blackhawk
    • Southwest Woodworks
« on: July 15, 2022, 02:46:15 PM »
Hello All,
Does anyone know of a 404 chain tie strap kit for repairing the Woodland Pro 46RPS ripping chains?  The preset tie strap needs to have a boss that will fit into a .190" diameter hole.
I use these on my Lucas slabber.  Here is a link to the chain:  https://www.baileysonline.com/woodlandpro-60-ripping-chain-loop-46rps-190-drive-links-for-lucas-mill-wpl-46rps190.html
Bailey's does not sell the tie strap kits for the Woodland Pro chains.  The hole in the Woodland Pro chain is .190" diameter, as I mentioned above.  I have some Oregon tie straps for their 27RX chain that I also use sometimes.  The Oregon straps have a boss that is .204" diameter.  So, they don't work together.
Just as a test, I took a short piece of Woodland Pro chain that I had and drilled the hole out with a #4 (.209 diameter) drill.  That makes the Oregon tie straps fit and rotate freely.  Any problem with drilling the hole larger if no one knows of a tie strap that will fit otherwise?
Lucas 7-23 with slabber.  Shopbot CNC 48x96
Offline Al_Smith
Re: Tie strap kit help for 404 chain
« Reply #1 on: July 17, 2022, 06:56:45 PM »
I may be mistaken but I think Wood Land pro was Baileys special made by Carlton .If  so I have a short roll of the last .404-.058 chisel skip Baileys ever sold when Gregg Grande was in marketing before Baileys was sold .Since that time I have not ordered a thing from them .If I think about it I'll get a measurement if that would help .However also if it is Carlton I'm not certain if they are still in business so it's finding somebody with a stash of it or E-Bay.
As to the question it's probably not going to hurt anything by drilling the hole out .
Offline blackhawk
« Reply #2 on: July 18, 2022, 09:51:05 AM »
Al - Thanks.  If you can get a measurement of that diameter, it would be appreciated.
I did find Carlton's website so it looks like they are still in business.  I'm not sure if Bailey's gets it from Carlton.  Baileys did tell me that the Woodland Pro came from Taiwan.  I did notice on Carlton's website that they were bought out by Blount International in 2008.  So, Blount could have a factory in Taiwan.
Offline Al_Smith
« Reply #3 on: July 18, 2022, 10:19:53 AM »
You can get a package of .404 tie straps on E-bay . I think  a dozen presets and ties for around 25 bucks which I think is high . However like everything else the prices have risen .Now then  regarding most chains I like Stihl Rapid Super as opposed to the same driver count on the bay they are only about 2-3 more bucks for a chain that lasts twice as long .So saying that some times cheaper is not actually better .
Offline Al_Smith
« Reply #4 on: July 18, 2022, 10:55:15 AM »
Well not much help .The plump size of the rivet is .203" on the Carlton chisel skip .
Offline blackhawk
« Reply #5 on: July 18, 2022, 11:34:40 AM »
I appreciate you checking the size.  Woodland Pro must be an oddball.  I'll just drill the holes larger.
LC strap
Started by brdmkr on General Board
Last post December 17, 2005, 12:29:18 PM
by getoverit
wrap and strap
Started by logman on Timber Framing/Log construction
Last post May 21, 2017, 10:26:16 PM
by ljohnsaw
man killed by shackle on tow strap
Started by rebocardo on General Board
Last post October 19, 2004, 02:55:47 PM
by Ron Wenrich
deer back strap
Started by thecfarm on FOOD! FOOD! FOOD!
Last post December 01, 2016, 07:43:06 AM
by drobertson
