Author Topic: Shot in the dark where did this hub come from  (Read 867 times)
Offline Wayne_Stevens
« on: August 12, 2022, 02:17:23 PM »
 Anyone seen a hub like this? It a brake drum too. It's on a log arch I picked up from a friend. His father pieced it together from scrounged parts. Never seen a hub like this.
Offline Southside
    • White Oak Meadows
Re: Shot in the dark where did this hub come from
« Reply #1 on: August 12, 2022, 02:59:54 PM »
Looks agricultural.
White Oak Meadows
Offline Patrick NC
  • I'm not new anymore, but still pretty green
« Reply #2 on: August 12, 2022, 09:04:52 PM »
Maybe early airstream camper or other trailer of the same vintage. Drop type axle maybe?
Norwood HD36, Husky 372xp xtorq, 550xp mk2 , 460 rancher, Kubota l2501, Case 1845 skid steer,
Online YellowHammer
  • Sawing is fun for the first couple million boards.
    • Hobby Hardwood Alabama
« Reply #3 on: August 13, 2022, 12:46:54 AM »
It looks almost exactly like the wheel hubs off my old rusted hay wagon, and also like the hub on our corn planter wheels.
YellowHammerisms:
Take steps to save steps.
If it wont roll, its not a log; its still a tree.  Sawmills cut logs, not trees.
Kiln drying wood: When the cookies are burned, theyre burned, and you cant fix them.  So dont burn the cookies.
Sawing is fun for the first couple hundred boards.
Offline Oliver05262
« Reply #4 on: August 14, 2022, 08:30:32 AM »
Can you make out the numbers on the casting? Any sign of a trademark?
Oliver Durand
"You can't do wrong by doing good"
It's OK to cry.
I never did say goodby to my invisible friend.
I woke up still not dead again today Willy
Dont use force-get a bigger hammer.
Offline GAB
« Reply #5 on: August 14, 2022, 01:52:00 PM »
Personally I have never seen a hay wagon or corn planter with brakes.
Now I must admit I seen them all.
GAB
Online YellowHammer
« Reply #6 on: August 14, 2022, 11:14:24 PM »
Oops, I didnt catch the part about the brake drum.  Yep, yer right, I aint got brakes on my hay wagon.  But the front of the hub looks exactly the same, even with that little bearing cover.  I guess theres so much rust it all looks the same.
YellowHammerisms:
Offline Southside
    • White Oak Meadows
« Reply #7 on: August 15, 2022, 01:00:25 AM »
Horse drawn wagons have brakes on them, often it's a hand lever you pull to activate it.
That is a slow speed bearing cap for sure, my planters and drills use the same design on the coulters.
White Oak Meadows
Offline Gere Flewelling
  • Hobby Miller
« Reply #8 on: August 15, 2022, 06:45:16 AM »
That looks a little like the rear axle set up on an old Chrysler mini-van from the 80's I used to have except that the axle has been cut.  Possibly from a smaller front wheel drive car.  Are the lug nuts metric?  Possibly from a foreign car.  That might explain the intense rust. ???
Old 🚒 Fireman and Snow Cat Repairman (retired)
Matthew 6:3-4
« Reply #9 on: August 18, 2022, 05:31:50 PM »
I'm thinking it is European, says 182 mm. Has a 13" tire/wheel on it, 155SR13. Has to be over 40 years old. 4.5" lug spacing. Lugs are part of the drum. Would like to find new wheels and bearings somewhere.
Just Before Dark
Started by etat on General Board
Last post May 29, 2004, 04:53:41 AM
by Swede
dark wood
Started by xlogger on Drying and Processing
Last post January 10, 2020, 05:55:24 AM
by nativewolf
Going to the dark side
Started by Splinter on Forestry and Logging
Last post February 05, 2009, 05:58:28 PM
by The-Burl-Hunter
Went over to the dark side
Started by alan gage on Firewood and Wood Heating
Last post December 29, 2018, 05:05:05 PM
by Magicman
