Author Topic: 445 rebuild to a 450  (Read 1081 times)
Offline Timbertron
  • Timbertron
« on: November 19, 2013, 02:08:41 PM »
so I have a Husqvarna 445 and I have a scored cylinder and piston due to a leaking decompression valve and I was looking to rebuild it and found that it will take a 450 piston and cylinder has anyone ever done this and how did it work afterword
Offline SawTroll
Re: 445 rebuild to a 450
« Reply #1 on: November 19, 2013, 02:56:00 PM »
I would look up the IPL(s) on Huskys website, to see what is different and what is not.  ;)
Information collector.
Offline Timbertron
  • Timbertron
« Reply #2 on: November 19, 2013, 04:49:32 PM »
everything is identical except the cylinder and piston and the stickers but short of that I just took about 2 1/2 hours and did the swap and seems to run good little bit more power from the feel but it will have to wait till this weekend to sink it in some wood and see how it really dose I was just wondering if anyone else did it and what the thought about it
Offline stihl for life
« Reply #3 on: November 24, 2013, 09:18:48 PM »
should bolt right on . but are u sure you got your scoring for a leaking d comp. ive never seen that ever. all a leaky d comp valve  will do is lower compression. i would look more into that to see what made the scoring.
help with ID and rebuild 795?
Started by hitter1 on Chainsaws
Last post March 04, 2020, 10:00:14 PM
by hitter1
Rebuild BW T-9?
Started by sandersen on Forestry and Logging
Last post September 14, 2015, 11:08:31 AM
by sandersen
024: rebuild, or ........
Started by MotorSeven on Chainsaws
Last post April 07, 2013, 08:53:31 AM
by thecfarm
LT 40 Rebuild
Started by whittle1 on Sawmills and Milling
Last post January 27, 2016, 09:38:04 AM
by paul case
