Author Topic: Steep ground  (Read 1159 times)
Offline Woodboogah
    • Blue Ribbon Outdoors
Steep ground
« on: July 19, 2014, 09:27:01 PM »
Tried taking some picture of the ground I am working on.  I dont think the picture does it justice
Keenan Logging & Tree Care, LLC
Offline SPIKER
Re: Steep ground
« Reply #1 on: July 19, 2014, 09:59:11 PM »
I know when I take pictures of some of my land and walk it I'm like ya tractor in to grab this log, or rock no problem.   Then get in the seat and pucker factor is got me glued to the seat well enough that I could roll it upside down & hang there without a belt  :D
Offline redprospector
Re: Steep ground
« Reply #2 on: July 20, 2014, 12:49:15 AM »
That's a pretty good slope. How long is it, and how much ground like that do you have to do?
Be careful, and keep her pointed straight up and down.  smiley_thumbsup
Offline jwilly3879
Re: Steep ground
« Reply #3 on: July 20, 2014, 06:45:58 AM »
The 240's can certainly climb.
Offline Woodboogah
Re: Steep ground
« Reply #4 on: July 20, 2014, 07:28:54 AM »
The whole property is really rocky and steep ground.  This particular spot is probably 6-700 feet until it somewhat levels off.  Next week I am going to see if I can work it from around the bottom of the hill and have less of a steep skid.  It will still be uphill but not like that.
Offline timberlinetree
Re: Steep ground
« Reply #5 on: July 20, 2014, 07:50:54 AM »
I get nervous going up the hills like something is going to snap and start going back words. I don't like going up hills in the winter with chains all around hitting ice and sliding backwards. Hills are very very dangerous. This picture doesn't show the slope very well either, but doesn't look like we have it quite as bad as you! Good luck and stay safe
I've met Vets who have lived but still lost their lives... Thank a Vet
Family man and loving it :)
Offline Woodboogah
Re: Steep ground
« Reply #6 on: July 21, 2014, 01:13:09 PM »
That's pretty steep.  For whatever reason today I was backing down in 1 low and my gear shifter popped out of gear not once but twice.  11 tons gets moving real quick on that steep slope.  Thank goodness for emergency brakes.  Pucker effect for sure!
Offline cutter88
  • any day you come home safe is a good day!
Re: Steep ground
« Reply #7 on: July 21, 2014, 03:53:51 PM »
That's a wicked hill but you got the right skidder for the job :) nice machine
Romans 10 vs 9
650G lgp Deere , 640D deere, 644B deere loader, 247B cat, 4290 spit fire , home made fire wood processor, 2008 dodge diesel  and a bunch of huskys and jonsereds (IN MEMORY OF BARRY ROGERSON)
Offline SPIKER
Re: Steep ground
« Reply #8 on: July 21, 2014, 04:01:20 PM »
... I was backing down in 1 low and my gear shifter popped out of gear not once but twice.  11 tons gets moving real quick on that steep slope.  ..
My tractor does same thing & I think it is because of way gears are cut, the revers is not meant to PULL or HOLD much load it is designed to go the other way and the gears push themselves out of gear.   Driving forward (PULLING) the gears set into themselves better, I have also had mine when going DOWNHILL have the load overdrive the tractor and PUSH it out of gear (same thing that the gears are working wrong way.)    That was NOT fun I had load of logs on trailer that weight was maybe 1.5~2x what tractor weighs.    :o   NOT fun, the trailer was hooked to 3pt box blade & FEL that I dropped onto the road to stop, brakes were useless.  left a small ridge in the road that I see & reminds me not to do dumb things every time I drive by it... ::)
Offline tj240
  • partner in Williams timber harvesting
Re: Steep ground
« Reply #9 on: July 21, 2014, 04:55:31 PM »
the 240 will do it i have the twin but mine a a 6 cyl duetze, most stable machine i ever ran i put it places i shouldnt
work with my father[jwilly] and my son. we have a 240 tj 160 barko[old] works great three generations working together
working the steep ground
Started by snowstorm on Forestry and Logging
Last post September 27, 2014, 05:56:13 AM
by SwampDonkey
Steep ground harvest of large cherry, poplar, beech
Started by Jasperfield on Forestry and Logging
Last post April 05, 2010, 08:14:23 PM
by Ron Scott
hollow ground (wheel) vs. flat ground
Started by Greg on Timber Framing/Log construction
Last post June 03, 2005, 11:40:30 AM
by Doc
Steep Terrain
Started by blkhillsvt on Forestry and Logging
Last post December 12, 2009, 12:29:13 AM
by ford62783
