Author Topic: Anyone ever seen one of these??  (Read 1504 times)
Offline boatbuilder
« on: May 20, 2021, 05:20:19 AM »
Well I've been after a farmi winch for a while now to put on my old L3750 and havent found any luck cracking the less than 2k price range. But I found this winch for sale, very reasonable, but can't seem to find any info on JD logging winch of any sort? Any of you ever seen one? And what are your thoughts on this one? Its about 4 hours from me so not a small job to go "take a look". Thanks
Offline thecfarm
Re: Anyone ever seen one of these??
« Reply #1 on: May 20, 2021, 05:35:03 AM »
Should have a ID plate on it somewhere.
But did someone repaint it?
The blade is interesting too. The older ones came with 2 legs.
Offline Ed_K
  • Leave it better than you found it. Ed_K
« Reply #2 on: May 20, 2021, 06:01:16 AM »
 Well it's 3pt and they all run good with not to many problems. The winch on the tree side isn't really good and the trailer hitch is too high but other than that I buy it.
Ed K
Offline stavebuyer
« Reply #3 on: May 20, 2021, 06:14:54 AM »
It looks heavy which may be an issue with a 3750 sized tractor?
Offline 47sawdust
« Reply #4 on: May 20, 2021, 06:17:06 AM »
I think I would keep looking.I have an L3750 , I also think it looks heavy.
Mick
Offline 711ac
« Reply #5 on: May 20, 2021, 06:57:37 AM »
I also thought it looks heavy,  until I  looked at the tractor side. Studying the spread of the lower pins in relation to the top link and pto. That makes me think it might not be as big as I originally perceived. If the price is great it might be worth a Sunday road trip. They sure hold their value if operational.
Online mike_belben
  • Pulp Friction
« Reply #6 on: May 20, 2021, 08:17:36 AM »
cat 1 and cat2 holes it looks like.  it sure aint a toy.  id put it on my dozer.
Isaiah 48:10
Offline boatbuilder
« Reply #7 on: May 20, 2021, 11:55:56 AM »
Thanks for all the input guys, weight is a concern for me thats why i was hoping someone might have a model or have seen one in the wild. I can't find anything on John Deere logging winches. He's asking 1200 which seems like a steal.
Offline Iwawoodwork
« Reply #8 on: May 20, 2021, 12:05:36 PM »
At that price I would have already bought it.   If it is more than your tractor can handle you can always resell it and get your money + back.
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #9 on: May 20, 2021, 12:14:20 PM »
That is an early Farmi of some kind. Very similar to my 306. I ran the 306 on an L3750, it was well matched. If it works, it's worth that much.
Offline boatbuilder
« Reply #10 on: May 20, 2021, 12:44:46 PM »
So you think its a farmi thats been painted JD colors?
Offline Resonator
  • Board Footage and Cord Woodage
« Reply #11 on: May 20, 2021, 12:45:07 PM »
Check if there is a minimum HP rating also. If you do get it, make sure you pull straight in line with the back of the tractor, the lighter the tractor, the more prone to tipping. Also a snatch block and skidding cone are good to have (pulled logs can and will find any rocks or stumps to hang up on).
Online mike_belben
  • Pulp Friction
« Reply #12 on: May 20, 2021, 04:05:34 PM »
@DeerMeadowFarm has one.
Isaiah 48:10
    • My homepage
« Reply #13 on: May 20, 2021, 04:35:11 PM »
Yes. I think it's a generation newer with that butt plate on it.
This is my 306:
Offline mudfarmer
  • Mama Tried
« Reply #14 on: May 20, 2021, 06:41:08 PM »
Can't kill the 306 apparently, I can think of three of us on here using those golden  oldies 8)
Offline 230Dforme
« Reply #15 on: May 20, 2021, 07:20:17 PM »
Good evening
I rarely post, however, look at what is
in the background of the photos
How long do you think that machine
has been sitting there ? And why?
A picture is worth a thousand words
Older, good equipment is out there
Keep looking
Offline boatbuilder
« Reply #16 on: May 20, 2021, 07:56:03 PM »
This is my 306:
Wow they do look similar. So consensus seems to be NOT a John Deere product but a Farmi. He says the distance between pins is 32" and has 2 heights 12" or 16". I think I'm going to pick it up. Any tips on what to look for when I'm there as far as operation goes? He doesn't have a tractor to fit it anymore so can't run it for me. Thanks for all the input folks, I appreciate it.
    • My homepage
« Reply #17 on: May 20, 2021, 08:25:50 PM »
Mine needs a new cable abd the free spool adjusted. I've had it 21 years. Probably close to 40 years old. It's typically been used on 50 hp or smaller tractors.
Offline Southside
    • White Oak Meadows
« Reply #18 on: May 20, 2021, 11:05:25 PM »
Is that up in the St John Valley by chance?
Offline boatbuilder
« Reply #19 on: May 21, 2021, 05:42:15 AM »
Thats the one.
