Author Topic: Rotary cutters- Bush Hog etc.  (Read 1296 times)
Offline 62oliver
Re: Rotary cutters- Bush Hog etc.
« Reply #20 on: June 03, 2021, 06:24:21 AM »
Thanks for the replies everyone!! I think I'm gonna plan on doing more chainsaw work and burning. I agree, those things seem like they would be rough on the gear when trying to cut the bigger stuff. That might be ok if you're getting paid to do it, but for a hobby guy might end up being costly.
Thanks again.
Husqvarna 266, Case 90xt, JD310C, TJ240E, 02 Duramax
Offline tawilson
« Reply #21 on: June 03, 2021, 07:20:38 AM »
I've pushed a lot of spruce trees over stump and all using the front end loader.
2017 LT40HDG35 WIDE
Woodmaster 725
Offline newoodguy78
« Reply #22 on: June 03, 2021, 03:41:43 PM »
I think your wallet will thank you for going at it with a chainsaw
Offline 62oliver
« Reply #23 on: June 03, 2021, 03:50:19 PM »
But I know my back and knees won't!!!
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
    • Behind the  Forestry Forum YouTube channel
« Reply #24 on: June 03, 2021, 03:56:57 PM »
Ill have a video in a week or two of me beating up me and my 8n today clearing some alder. You can use me as an example of what not to do, and still get it done.  I wish i could find someone up here with a mulcher. It'd  be light work for what was a tractor and operator workout with a 5' brush hog.
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
« Reply #25 on: June 03, 2021, 04:16:26 PM »
Itís like everything else, there are limits to what equipment and hand and power tools can do. So pushing, sawing, dragging, are all realistic options, but if I have acres to clear, and the trees arenít too big, then Iím going to let the Bush Hawg eat. Itís not a tree cutter, but if I can bend a sapling over and get it under the deck, in reverse, the chips will fly.
Incidentally, even if I cut a tree down with limbs, Iíll still pile the smaller limbs out in the field and grind them up.
There are different styles and makes, but big blades, big bolts and big hp get er done.
My buddy up in Tn has fields covered in grapefruit sized rocks, and new ones sprout every spring.  He runs his cutter over them every year until they are gravel.
YellowHammerisms:
Take steps to save steps.
If it wonít roll, its not a log; itís still a piece of tree.  Sawmills cut logs, not pieces of trees.
Kiln drying wood: When the cookies are burned, theyíre burned, and you canít fix them.  Donít burn the cookies.
Online Wudman
  • Eat, drink, and be merry before you go on quota!
« Reply #26 on: June 03, 2021, 05:24:51 PM »
I have a five foot Hardee at the moment.  I have been working on clearing under the pine plantation around the house after it was thinned. For the bigger stuff that I don't want to ride over with the tractor, I drop it with the chainsaw and then limb it with the rotary cutter.  I don't care about chopping up the main stem, but minus the limbs it will decompose in short order (sweet gum mostly - mush in a couple of years when laying on the ground).
Wudman
ďYou may tear down statues and burn buildings but you canít kill the spirit of patriots and when theyíve had enough this madness will end.Ē
Charlie Daniels
July 4, 2020 (2 days before his death)
Online Wudman
« Reply #27 on: June 03, 2021, 05:27:26 PM »
A live PTO goes a long way when hogging brush.  Not being able to clutch yourself backwards is a pain.  I feel for you on the 8N.  Great little tractors, but not the best in the world when needing the PTO.
Wudman
Charlie Daniels
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
« Reply #28 on: June 03, 2021, 05:47:21 PM »
He was in the soo with his mom and dad camping. I invited him by text message.
Offline chevytaHOE5674
« Reply #29 on: June 03, 2021, 08:00:40 PM »
I've probably cleared 150 acres of this kind of brushy stuff in the past few years with my old 8' Rhino AG mower. I've put new u-joints in the pto shaft and frictions in the slip clutch. Zero tires during the process just a tubeless valve stem or two. The expense of those parts is cheap compared to what a back surgery would cost from chainsawing or the bill from a mulcher.
When done it looks like this. Usually do it twice in one season then feed hay on it to the cattle all winter. By the 2nd summer I have some good pasture.
Offline Don P
    • Calculator Index
« Reply #30 on: June 03, 2021, 08:21:35 PM »
Quote
We're pretty much the same except they are everything from house sized icebergs to the aforementioned gravel. They say these mountains were 10,000 feet taller before white man came with the bush hog.
I went into the tractor repair shop with the gizzards of the bush hog gearbox in a sack. Carl said "you guys with cabs never hear it when you hit the rocks". "What cab! I was on a TO35 and fell in an old outhouse hole full of rocks  :D" You learn pretty quick not to whip your head around to see what's making the racket. Duck, half clutch, lift and roll. If you hit a bee nest be very still, they'll wear out the moving shaft, if you start flailing they gotcha.
If some bright young draftsman has put a linch pin on the tail wheel replace it with a bolt and nylock nut. Sooner or later a twig is going to flip that bail while you're backing into a rose and after you find it the wheel will wobble like a bad shopping cart from then on.
The future is a foreign country, they will do things differently there - Simon Winchester
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
« Reply #31 on: June 03, 2021, 08:48:27 PM »
I was wearing my muffs with my hard hat today, as I have had exactly what greg was talking about happening, bringing trees down on you. I think the muffs were a mistake as I couldnt gauge engine rpms. Im pleased with my results so far.
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
« Reply #32 on: June 03, 2021, 08:50:53 PM »
@chevytaHOE5674 , looks like we were working in the same field a whole U.P. apart!
Offline bitternut
« Reply #33 on: June 03, 2021, 10:32:43 PM »
Yeah Jeff it could be mistaken for the same field. Good job both of you. How many fawns did you roust out of their beds? Fawns are one of the hazards you encounter while mowing. I usually run with the bucket down low in the grass to flush them out.
I have a Bush Hog BH26 mower. It is rated for tractors 45 to 130 HP with the gearbox rated at 130HP. The unit comes with a slip clutch standard. Very heavy unit at a listed weight of 1095 #.  It has a rated capacity of 3" diameter. Oliver62 it is a very rugged mower and I have cut some thorn apples that diameter but you definitely know when you do. I try to avoid doing so whenever I can. Pretty hard on the mower and your tractor I think. My tractor is on the low end of the HP required and your 100HP would fall in the upper end. I think you would be quite happy with the same mower for a long long time. Definitely steer clear of the John Deere mowers. They have lots of issues.
Offline Skeans1
« Reply #34 on: June 04, 2021, 12:44:19 AM »
Have you considered something like a shredder flail mower?  Vrisimo makes some really heavy duty units we have a 9í 500 series thatís over 2000 pounds and is made for shredding limbs etc.
Old rotary mill, what is it?
Started by MrPorter on Sawmills and Milling
Last post March 27, 2017, 07:53:19 PM
by moodnacreek
Rotary Joint
Started by rick f on Forestry and Logging
Last post February 15, 2011, 12:13:22 PM
by mad murdock
Rotary welder?
Started by Satamax on General Board
Last post July 03, 2013, 03:59:26 PM
by Al_Smith
rotary embossing
Started by Cedarman on General Woodworking
Last post October 05, 2008, 08:22:21 AM
by Cedarman
