Hydraulic lift table
Started by PAmizerman, January 16, 2023, 07:35:54 PM
PAmizerman
Let me know what you have
4'x12' would be ideal
Hydraulics everywhere
Woodmizer edger 26hp cat diesel
Traverse 6035 telehandler
Case 95xt skidloader
http://byrnemillwork.com/
WM bms250 sharpener
WM bmt250 setter
Crusarius
You may want to look into get a couple smaller tables and building a top to go across both of them. a table of that size is going to be very hard to find and very expensive.
KirkD
I have a motorcycle lift that is wide enough to drive a quad on. You can get them in air, hydraulic or an electric motor for the lift part. If you want the table larger you could mount a wood top over it.
Just a thought.
Wood-mizer LT40HD-G24 Year 1989
farmfromkansas
Harbor freight has a motorcycle lift that measures about 3 x 8.  I use one as a variable height work table.  Raise it up to desk height for a single board, lower it to build boxes and cabinets, lower yet for sanding a chest of drawers.
