Author Topic: Beam span  (Read 45954 times)
Offline beenthere
Re: Beam span
« Reply #40 on: November 07, 2003, 03:19:40 PM »
I'm curious why you are going so narrow (14')  ???
I would expect I would feel real confined in such a narrow and long building. But figure you have a plan, or a restriction that makes sense.
Offline Neil_B
Re: Beam span
« Reply #41 on: November 07, 2003, 07:04:47 PM »
Will post a pic of my layout. Everything should flow from one end to the other. Just need it wide enough to work in as narrower is cheaper and longer is easier to layout without tripping over things ;)
Timberwolf / TimberPro sawmill, Woodmizer edger, both with Kubota diesels. '92 Massey Ferguson 50H backhoe, '92 Ford F450 with 14' dump/ flatbed and of course an '88 GMC 3500 pickup.
Offline rllintz
Re: Beam span
« Reply #42 on: September 25, 2022, 05:25:50 PM »
I have a unique situation that Im having trouble working out. I am making a bent with about an 8/12 pitch that spans 30. Im using red and white oak. It will not have a roof. Its for an entrance to a ranch. It will have two top chords, a king post, two struts, and a bottom beam. Heres what Im thinking so if anyone has any comments Id greatly appreciate them.
The materials are red and white oak.
2 posts. 10x10x8
2 knee braces. 10x10x6
1 top plate. 10x14x32
1 king post. 10x10x8
2 top chords. 10x10x17
2 struts. 10x10x6
My concern is whether a 14 beam can carry the load without sagging. Theres no roof or snow load. Its just a bent at the entrance to a ranch. Please if you have nasty comments just dont bother responding. Constructive comments are greatly appreciated.
Offline rllintz
Re: Beam span
« Reply #43 on: September 25, 2022, 05:27:42 PM »
I forgot to mention that the 10x14x30 beam will not be scarfed. It will be milled to length.
Offline Jim_Rogers
  • Board Moderator
  • Keep your chisels sharp.
    • jrsawmill.com
Re: Beam span
« Reply #44 on: September 25, 2022, 05:31:20 PM »
I can understand that this is an entrance to a ranch, but 8' post seem kind of short.
Will they be up on some concrete piers to get the clearance under the bottom chord of the truss?
Jim Rogers
Offline rjwoelk
    • countrysidefirewood
Re: Beam span
« Reply #45 on: September 25, 2022, 07:33:30 PM »
If you need to get a moving truck or semi in min 13'6" go 14 or 16 ft clear.
Lt15 palax wood processor,3020 JD 7120 CIH 36x72 hay shed for workshop coop tractor with a duetz for power plant
Offline Don P
    • Calculator Index
Re: Beam span
« Reply #46 on: September 25, 2022, 07:47:24 PM »
You won't be wrong using 60 lbs per CUBIC foot (12 BF) for green oak.
Then plug it in here;
Untitled (forestryforum.com)
That is checking the wood strength, the joinery is the next kettle of fish.
A metal cap formed for the top will help it last longer. And of course the more white the better. I borate and then put a water repellant finish on porch posts and such.
The future is a foreign country, they will do things differently there - Simon Winchester
question
Beam span and general structure information for post and beam pavilion
Started by Eric_M68 on Timber Framing/Log construction
Last post February 04, 2021, 06:39:17 AM
by Don P
Beam span Calculator
Started by Dstrnad on Timber Framing/Log construction
Last post March 31, 2013, 05:38:26 PM
by Jay C. White Cloud
Sawmill Shed - Beam Span
Started by sdboers on Sawmills and Milling
Last post October 24, 2020, 09:12:26 PM
by JBS 181
Help wanted on Beam Span and Strength
Started by dlincoln on Timber Framing/Log construction
Last post March 01, 2019, 09:39:38 PM
by Don P
