Author Topic: Lucas Slabber  (Read 1320 times)
Offline Clevelander
  • Livin the dream
Lucas Slabber
« on: January 25, 2016, 04:17:38 PM »
I'm considering buying a Lucas Dedicated Slabber with an additional 8" powerhead to run the planer attachment and sander. What kind of experiences are out there slabbing over 36" material?
Live your truth and your truth will find you
Offline bkaimwood
  • Life's too short to sweat the small stuff
Re: Lucas Slabber
« Reply #1 on: January 25, 2016, 06:23:24 PM »
A bit vague on the question, but here I go...what experiences come from 36" logs? A lot of backbreaking handling, sawing, lifting, dusting, stickering, drying, and space....followed by the reward of the beautiful slabs you've sawn, as you admire each one as sawn (while clenching your spine)...and in each of the following steps listed above. The next reward, is when you sell them. The best reward, is, by far, when you make something yourself from one.... Then is has gone full circle, from log to table. All the kidding aside, very rewarding, but VERY hard work... Almost necessitates proper support equipment, or a few strong young and dumb helpers, like most of us used to be...
bk
Offline terrifictimbersllc
    • Terrific Timbers LLC
Offline Clevelander
  • Livin the dream
Re: Lucas Slabber
« Reply #3 on: January 25, 2016, 08:56:25 PM »
Thanks BK and Terriffic. Bk I hope to head off a bit of the backbreaking aspect with a knuckleboom truck with a vacuum lift to set the slabs and kiln plates but there is nothing like experience, which I don't have much yet.
Terriffic, thanks for the link which I hadn't seen until after I posted this one.
Offline Grandedog
    • Left Coast Supplies
Re: Lucas Slabber
« Reply #4 on: January 27, 2016, 10:06:38 PM »
     Howdy Cleavelander,
     Sorry for the delayed response. Part of the reason I'm on here in the evening is that we've just had our best week in Lucas Mill Sales so far, and there's still a couple days left. I think I might have spoken with you on the phone if you were the person looking for the Super Dedicated Slabber with the 9' width of cut. If it wasn't you, give us a call and we can answer any questions you might have.
Regards
Gregg
Gregg Grande
Left Coast Supplies LLC
1615B South Main Street  Willits, CA 95490
888-995-7307  Ph 707-602-0141                   Fax 707-602-0134  Cell 707-354-3212
E-Mail  gregg@leftcoastsupplies.com   www.leftcoastsupplies.com
Offline xlogger
Re: Lucas Slabber
« Reply #5 on: January 28, 2016, 05:44:02 AM »
Will the 18hp motor supply enough power on the slabber to cut wide logs?
Offline Grandedog
Re: Lucas Slabber
« Reply #6 on: January 28, 2016, 12:23:15 PM »
     Howdy,
  The 18HP has plenty of power in the 60" cut. You might have seen the special we're running on them. http://www.forestryforum.com/board/index.php/topic,87686.0.html  We're doing it because Lucas is moving to the 23HP on both models. That way they only need to have the one engine emission rated. We have some of the new versions in stock if you're interested give us a shout.
Regards
Gregg
Gregg Grande
Lucas gearbox, and LUCAS SLABBER DRIVE HUB pictures wanted
Started by shelbycharger400 on Sawmills and Milling
Last post September 04, 2011, 11:32:02 PM
by shelbycharger400
Peterson or Lucas Slabber?
Started by bkaimwood on Sawmills and Milling
Last post May 22, 2017, 09:05:16 AM
by ButchC
New Style Lucas Slabber Bar
Started by Lucas_USA on Lucas Mill
Last post April 11, 2018, 06:22:20 AM
by xlogger
Lucas slabber washboard
Started by Seaman on Sawmills and Milling
Last post January 20, 2013, 09:56:19 PM
by logboy
