Blade Can
Started by Magicman, August 07, 2014, 02:20:42 PM
After over 12 years of use, abuse, and misuse, my "Magic Can" badly needed replacing.  My farmer customer even noticed it Monday and offered me an empty cattle feed container.
I had even riveted a strap across the largest crack to hold it together.
This 32 gallon sized container has an 18" bottom and will work.  (note: 16" bottom will not work.)
The new container is also much better reinforced on the bottom.
I measured 12" up from the bottom and scribed a cut line.
And then proceeded to cut the bottom off.
The top portion containing the handles also had to be cut off, leaving the center portion unused.
Of course the top is now larger than the bottom. so a 4" section has to be trimmed off to make it fit.
I fitted the top portion inside of the old can, but this one will be on the outside.
I used rivets to connect the two sections together.
Riveted together.  I left the top portion about ΒΌ" higher than the lower.
Here the new can is shown with the scraps that were removed.
And the new can shown with it's old worn out predecessor.  I tried using some Gorilla Tape above the handles and where the split section of the upper portion came together.  If if stays, OK.  If it get's ragged, I will remove it because it was just for looks anyway.  A rubber bungee cord will keep the top on.
Presenting the new Magic Can.   ;)
tmarch
Pretty snazzy, nice work.   :)
Retired to the ranch, saw, and sell solar pumps.
Gadrock
I thought it would have been in a different color...hummmmm
David G
carry on
LT40 G18,   bent Cresent wrench,   broken timing light
Prentice 280 loader, Prentice 2432 skidder, Deere 643J fellerbuncher, Deere 648H skidder, Deere 650H Dozer
Bruno of NH
Mr Magicman ,
Looks great nice work !
Jim Bruno of NH
Deese
You ain't right Magic  smiley_devilish
But I like it  ;D ;D
2004 LT40 Super 51hp w/6' bed extension
Cooks AE4P Edger
Cat Claw sharpener/Dual Tooth Setter
Kubota svl75-2 skidsteer w/grapple, forks, brushcutter
1977 Log Hog Knuckleboom loader/truck
POSTON WIDEHEAD
You're killing me Magic.  :D
21incher
Nice job on the blade can. Another Magicman solution to an age old problem :D
hackberry jake
You could've left it the original height if you didn't have a debarker. See how much time not having a debarker would've saved!  stupid_smiley
rasman57
That is Old Skool Kool rigging right there.  Making it work with no bells and whistles.  Rivets and tape yes.... but no bells no whistles.    Cool.   :o
drobertson
Using the can now brings on a totally different perspective ;D  nice work, and a great friend and customer for sure,  those cans are very useful.
Deese
Quote from: hackberry jake on August 07, 2014, 06:50:24 PM
Good One!
Cooks AE4P Edger
backwoods sawyer
and you only have one blade can, sharp-dull?? two would make you the double can man ;D
Backwoods Custom Milling Inc.
thechknhwk
Quote from: backwoods sawyer on August 07, 2014, 11:37:34 PM
Then everbody would be checkin' out his cans; it may make him a lil uncomfortable.
Actually, since the "Magic Can" only holds 10/11 blades, when I am on the road sawing I put a cube of blades in the truck back seat.  I have never used much over 10 blades, but at least I know that they are there.
BCsaw
Gotta like a man with a plan. Nice to be neat and organized! ;D
Inspiration is the ability to "feel" what thousands of others can't!
Homebuilt Band Sawmill, Kioti 2510 Loader Backhoe
biggkidd
Nice, clean, lite and, effective!
I like it!  smiley_clapping
Echo 330 T, Echo 510, Stihl Farm Boss, Dolmar 7900, Jinma 354 W/ FEL, & TPH Backhoe, 1969 M35A2,  1970 Cat D4
Building a Band Mill  :)
Ribsy
Thats a cute Brute, Magic. Nice Job!  8)
Engaged in tree work, tree removal, milling and and processing said product into high quality and well seasoned lumber slabs and firewood.
ARp
Lynn,
Thanks for sharing the Magic Can!  You may see duplicates in Texas.
Thanks  8)
Allen
scsmith42
Quote from: ARp on August 10, 2014, 12:23:45 PM
Lynn,
Thanks for sharing the Magic Can!  You may see duplicates in Texas North Carolina!
Thanks  8)
Allen
Lynn, thanks for the great idea!
Tom's 3638D Baker band mill
Peter Drouin
That's one way to keep blades :D
captain_crunch
guess this is why he be called Magicman
M-14 Belsaw circle mill,HD-11 Log Loader,TD-14 Crawler,TD-9 Crawler and Ford 2910 Loader Tractor
backwoods sawyer
A handy can for keeping saws while on the road, I have been using a nursery tree pot for the same reason.
ljmathias
Another reason I love being stationary: blade goes dull, pop it off, work over to the barn, sharpen it up (I'll set up my setter next week so do that, too), walk back to the mill and back to cutting.  Usually do two or three blades while I stack boards, oil or clean up the mill.  Makes a nice break from cutting noise and vibration.
But you all are right, they don't call him magicman for nothing (or do they?  Inquiring minds are wondering, what magic did he do to get the name in the first place?).
Lj
LT40, Long tractor with FEL and backhoe, lots of TF tools, beautiful wife of 50 years plus 4 kids, 5 grandsons AND TWO GRANDDAUGHTERS all healthy plus too many ideas and plans and not enough time and energy
Actually I got it back in the early 70's when I was a telephone co. PBX repairman.  I loved troubleshooting electronics and the other guys thought that I could make problems disappear....like magic.
POSTON WIDEHEAD
Quote from: Magicman on August 13, 2014, 10:57:57 PM
You showed them....you disappeared from the phone company....like magic.  :D
