Ultrasonic cleaner
Started by Bruno of NH, April 06, 2024, 02:45:39 PM
Bruno of NH
I purchased a Creworks ultrasonic cleaner off Amazon 5 weeks ago.
Finally tried it out today on 2 walbro carbs from my chainsaws.
It worked great . Put the carbs in a glass jar with carb cleaner . Then ran them with just dawn and water.
Took a stock Echo air cleaner that was almost black. Put it in with dawn and water and it came out looking almost new.
rusticretreater
Is the liner stainless steel and easily cleaned or is your cleaner now very unclean?
Kubota BX25
Homemade Log Arch
Husqvarna 562xp
Bruno of NH
It's stainless steel
Clean as a whistle after use
Southside
Our incubators run an ultrasonic device in the water reservoir to keep the humidity right in the chamber, it's amazing how the air that the vapor blows into looks like something out of a graveyard movie scene at night.  Pretty neat technology for sure.
White Oak Meadows
scsmith42
I love my ultrasonic cleaners! (I have three).  Two of my three are used units from dental offices and they work great.
Re carb's - I've found that using the cold immersion dip type carb cleaner in the ultrasonic cleaner turns out best.  I'm doing vehicle carbs though - not chainsaw carbs so there is usually a greater buildup.
Tom's 3638D Baker band mill
Raider Bill
My advice on aging gracefully... ride fast bikes and date faster women, drink good tequila, practice your draw daily, be honest and fair in your dealings, but suffer not fools. Eat a hearty breakfast, and remember, ALL politicians are crooks.
Bruno of NH
I need to pick up some simple green.
Do they clean as good on the lower heat settings?
doc henderson
what size did you get Bruno?
Raider Bill
Quote from: Bruno of NH on April 08, 2024, 07:40:45 AMI need to pick up some simple green.
Mines a cheap HF one. No settings.
Bruno of NH
Doc 6 liter
I used it again this last week end
Works great
doc henderson
Thanks Bruno.  I will get one based on your recommendation.
