Forum Mouse Calibration Testing
Started by Jeff, January 04, 2008, 02:01:58 PM
MOUSE CALIBRATION
Doing research on possible causes of Forestry Forum time outs and things of that nature, I found out something really weird. Some of these problems actually originate from your mouse, and if the mouse is not calibrated correctly, the clicks are off and the page can die. You can have your tabbing go a kilter and any number of funny things go on. It's pretty easy to test the calibration with a test from this post.
You should probably do this every few days. More often if you spend a lot of time on your computer.
To re-calibrate your mouse, click and hold on the Y below. Then drag the Y toward the G. If it doesn't work, you might want to clean your mouse.
You really need some help.
You'll believe anythin
g
Report Your Results
