LT15Wide Not Starting After 1 Month Idle
Started by Pepe_Silvia, October 23, 2019, 09:26:33 PM
Pepe_Silvia
I wasn't able to run my saw for about a month, and now it won't start.  I don't know how old the fuel was, but at most a couple-few months old. I can get it to fire with carb cleaner and checked that it is pumping fuel into the carb, so I think that basically narrows it down to the carb being gummed up.
First of all, I typically just shut it down after use, but I'm thinking maybe I need to start shutting off the fuel shutoff and letting it starve itself, is that correct?
Second, is there a 'quick fix' on this?  Maybe one spot where it's prone to gum up that I can get to without taking the whole carb apart?  That's probably wishful thinking.
Saw is an LT15Wide with the 25HP Kohler.
Woodmizer LT15Wide GO, John Deere 318D Skid Steer
Just Right
You could try SeaFoam to see if that helps.  Other than that,  rebuild the carb.
If you are enjoying what you are doing,  is it still work?
Southside
I let my welder sit once too long, same engine, and it was just a case of taking the carb off and cleaning it really well.
John Bartley
One month should not be anywhere near time enough to gum a carb with bad fuel.   My guess would be water in the carb bowl.  Try doing a carb bowl rinse first.  If there's a drain screw do that first, then only remove the bowl if you have to.
EDIT : a 25hp Kohler will not likely have a drain screw.  You could start it and keep it running with a squirt bottle while you choke it to suck the water out of the bowl.  I can't believe that fuel could go bad in a month.
Kioti DK35HSE w/loader & forks
Champion 25hp band mill, 20' bed
Stihl MS361
Stihl 026
Chuck White
I have a 25hp Kohler on my mill, but I don't remember if there's a drain plug on the bottom of the carb, but if there is, drain it and feed it some fresh gasoline!
I only use 91 octane, non ethanol gas in my small engines!
Pepe_Silvia
Thanks for the advice everyone.  I took the carb apart and cleaned it as suggested and it works now.  So either bad gas or water.  There was some green corrosion on the interior parts.  Is this indicative of water?
There turned out to be no drain on it.
charles mann
for copper/brass, green is indicative of corrosion, aluminum, white. as recommended, run a little seafoam even though you got it running. my miller has a kohler and i let it sit for a while too, but my fuel tank is below the engine. i poured a couple bottles of denatured alcohol in the tank, put 5 gal of 100LL av gas and let it sit for a couple hrs. since the lift pump is whacked, i installed a primer bulb from a boat fuel tank, primed it, turned it over and it fired right up. i now only run 100LL in ALL my air cooled engines, including my chainsaw.
Temple, Tx
firefighter ontheside
I've never ran my kohler engines dry of fuel, but I do shut off the fuel petcock.  My mower always starts fine the next spring.  If you're going to let it sit that long, put a little bit of sea foam or other stabilizer in once in a while.
Woodmizer LT15
Kubota Grand L4200
Stihl 025, MS261 and MS362
2017 F350 Diesel 4WD
Kawasaki Mule 4010
1998 Dodge 3500 Flatbed
Quote from: Pepe_Silvia on October 23, 2019, 11:04:50 PMThere turned out to be no drain on it.
I'm surprised because most small engines have a drain screw on the bottom of the float bowl.
Pepe_Silvia
Quote from: Magicman on October 25, 2019, 08:43:31 AM
I don't know a whole lot about them, but this seems to be a little bit different design.  The bowl is basically part of the body of the carb.  There's a solenoid on the side (it attaches where the brass part is in my original post) that could probably be removed to drain the bowl, but I'm not sure the screws are accessible while the carb is mounted.
This isn't my picture but I snagged it from a youtube video I watched.
Ed_K
 I had problems with my garden tractor not starting if not used every day. It ended up that electric shut off on the side of the carb was sticking. Just a little sticky film on it and it wouldn't open. Not saying what happened to that rod ;D.
Ed K
Don P
On the denatured alcohol thing, I've removed the fuel pickup tube from the tank and stuck it in a bottle of fuel treatment (denatured alcohol) and sucked up a very healthy snort. The alcohol will mix with water and also mixes with gas so it soaked up the water that was in the bowl and it got burned over the next couple of minutes of rough running.
Pepe_Silvia
Well, it wasn't actually running as well as I thought.
When putting the carb back together the gasket was curling on me and would not seat properly.  I got it back in as best as I could.
It would run at first, then got to where it was dying every time I throttled down.
Eventually it stopped running and would cough but not start.
I ordered a new gasket, got it in today.  Went ahead and siphoned all the old gas out of the tank as best as I could, unhooked the fuel line and cranked the motor a few times to clear the line.  When I was putting it back together, the spring that wraps around the throttle and is connected to the carb and linkage came off, and I'm not 100% sure I put it back on in the right place.
At idle now it cycles between idling well and almost dying.  At full throttle it surges.  When I throttle down from full throttle it dies.
I'll try to take some video if that will help.
btulloh
That spring must be related to the governor and you probably put in the wrong place so the engine is hunting.
Do you have a manual for the engine?  Or you should be able to find it on a parts diagram online.
Sounds like the gasket and the other things you did took care of your original problem.
HM126
Pepe_Silvia
I found the manual here: http://www.kohlerengines.com/engines/onlinecatalog/pdf/24_690_06_EN.pdf
It is the spring that's on part F here, the throttle linkage.  It looks like I have it in the right place.
Ed_K
 I found that when my engine was surging/hunting the float was not set right.
Ed K
btulloh
X2 on the float.  I'm not a real good carb guy and I always think the float is adjusted OK because I didn't change it when I'm rebuilding a carb.  I'm usually wrong.
The real story is everything needs to be right with the carb and linkage and it's easy to miss something.  If the original problem was a gummed up carb, it's also easy to miss cleaning some of the tiny internal passage ways.
Another thing that gets skipped with a casual cleaning is removing the Welsh Plugs - the little domed things that look fragile (they are). They are usually supplied with a rebuild kit.  Removing them allows access to the internal passage ways that like to gum up.
HM126
sealark37
Just a re-cap of the obvious.  Are you using ethanol-free gas?
Pepe_Silvia
Quote from: sealark37 on November 09, 2019, 09:04:11 AM
I'm not.  Ethanol-free is not readily available around here.
Pepe_Silvia
Quote from: Ed_K on November 09, 2019, 08:36:31 AM
Thanks for the tip.  I've never adjusted a float before, but I'll search and see what I can find.
Any tips?
Pepe_Silvia
I found a video that gave me a pretty good gist of how to do it.  I adjusted it so the float cut off later and it was running a lot better.  It was still struggling when I cut it off at full throttle, and wasn't idling perfectly, so I decided to go a little bit further.
This time I ended up leaking a bunch of fuel out of the carb.  It's either because I adjusted too far, or I didn't get the gasket to seat right.  I swear the gasket gets bigger every time I take it apart.
Is it possible to over adjust to the point the fuel leaks out, or is this likely just the gasket?
Is there a proper way to get the gasket to stay in place?  You can see here it's quite a bit bigger than the seat it's supposed to go in.
jeepcj779
I think gaskets like that swell when they absorb fuel or oil. You can try boiling it for a few minutes to get the oil/fuel out, then let it dry and it should fit again. This does not always work, but if you were going to trash the gasket anyway, it is worth a shot.
Pepe_Silvia
Quote from: jeepcj779 on November 09, 2019, 12:10:30 PM
Good call.  I used a hair dryer and it shrunk down to a manageable size.
I think I over adjusted because it is flooding now.  I can't find the spec for setting it so I guess I'll continue with the 'guess and check' method.
btulloh
Try to find the spec.  Guessing is frustrating and seldom leads to anywhere good.
The adjustment is very fine and very critical.  We're talking in the few thousandths here.  Also, a float can get a pin hole and take on gas internally and throw it out of whack (technical term :D).  Alcohol makes the pinhole problem worse because alcohol will go through a smaller hole than gas will.  I had a pinhole problem one time where a different brand of gas would pass through a pin hole but my normal brand would not.
HM126
Pepe_Silvia
I've checked Kohler, Keihin and Woodmizer and can't find the spec.  Is this something Woodmizer would be able to provide me if I call them?
