SPACE AVAILABLE
SPACE AVAILABLE
Author Topic: Southeastern VA ornamental bush ID  (Read 887 times)
Offline VB-Milling
  • Always learning
« on: February 28, 2022, 11:38:59 AM »
Originally, we thought it was Prunus laurocerasus (Cherry Laurel), but now we have our doubts.
Whatever it is/was, it was left to grow out of control as a property barrier/separation.  It grew to about 22ft, fast growing, soaking wet (weeps water almost instantly after cut).  I topped it 2 years ago and it grew about 4ft in that period of time.
I have included pics showing it in both summer months and winter months.
We decided we didn't want to constantly trim it and it wasn't really all that ornamental so we just decided yesterday to cut all 6 clusters down.  It was basically like taking down 6 trees.
HM126
Offline ESFted
  • Just a chain saw, so far.
Re: Southeastern VA ornamental bush ID
« Reply #1 on: March 02, 2022, 12:10:24 PM »
Perhaps one of the privets?
S.U.N.Y. College of Environmental Science and Forestry '65
Stihl MS661CRM, Stihl MS460,  Stihl MSE 220, Solo 64S, Granberg Alaskan MK-IV CSM
Dreams of a Wm LT70 w/all the accessories
Online btulloh
« Reply #2 on: March 02, 2022, 12:47:22 PM »
The closeups look like privet. Is it blooming now?  Have you seen clusters of little white berries on it in the past?
If its privet, I would classify it as a menace more than a shrub. Treat a fresh cut stump with some form of triclopyr to get rid of it. Otherwise difficult to control. Must be treated immediately after cutting to be effective.
If its not privet and youre trying to get rid of it, the cut stump and treat method will work just as well.
HM126
Offline VB-Milling
  • Always learning
« Reply #3 on: March 07, 2022, 10:38:11 AM »
Not a spring bloomer. I think it would bloom early June based on my previous pictures. Definitely a menace.
I'd run the lawn mower by it weekly during spring/summer/fall months and never noticed white berries.
HM126
Offline rusticretreater
  • I finally have enough wood!
« Reply #4 on: March 07, 2022, 11:17:07 AM »
Can't determine the variety from the pictures .  It does appear however to be one of the many privet varieties that grow in Virginia.  Many are invasive and imported.
https://www.invasive.org/alien/pubs/midatlantic/privets.htm
You can try the various plant killers or you might try digging it out. Maybe get one of those choker chains and pull 'em out.
Kubota BX25
Homemade Log Arch
Husqvarna 562xp
Offline VB-Milling
  • Always learning
« Reply #5 on: March 08, 2022, 11:37:34 AM »
Appreciate all your replies guys. Thank you.
We went ahead and cut them down and had the stumps ground down 12inches below the surface. I'm sure I'll be chasing growth for a while but the were way too big to pull out. Chemical treatment is our next option although they exist in the drainage swale between my property and the neighbors. When it rains, water sheet flows through this area. Going to make treatment tough. Also going to make establishing grass tough as it may wash out. It'll get plenty of water though if it has time to established roots just like the bushes did!
Offline beenthere
« Reply #6 on: March 08, 2022, 01:16:47 PM »
Hope she doesn't slip and fall on those sharp stubs.
« Reply #7 on: March 08, 2022, 02:50:11 PM »
Hope you don't see more of the neighbors than you bargained for. :o
Kubota BX25
Homemade Log Arch
Husqvarna 562xp
SPACE AVAILABLE
