Author Topic: Sawmill satisfaction poll  (Read 15941 times)
Offline Buzz-sawyer
  • To see it is to saw it....
Re: Sawmill satisfaction poll
« Reply #80 on: January 03, 2004, 08:19:37 PM »
I prefer to be the guy carrying the two wooped workers away!!!!
8) 8) 8) 8)
    HEAR THAT BLADE SING!
Offline Sawyerfortyish
  • Bigger they are the more mess they make
« Reply #81 on: January 04, 2004, 06:20:35 AM »
Corley I'm cuttin 4000 ft and I only have help til noon. Don't cut it every day but have cut as much as 10,000 in a day when I have the help if your set up right it's not such a big deal. Two guys to tail and one with a loader to keep the logs coming and the lumber going
Buzz if your cuttin osage that stuff and locust is about the worst stuff you can throw at a saw it's like cuttin steel almost you cant keep the corners on the bits
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #82 on: January 04, 2004, 08:45:57 AM »
  Enough help is the key.  We've cut 8 in a day but that's pushing it and that's with nice clean straight logs not too big not too small, two guys tailing, Grandpa running the stick and me riding the carriage running the setworks and dogs, the edger running full time and you're tired at the end and there's still clean up to do.
 When this mill was running production in the 40s and fifties they were putting out 10,000 bdft a day with a crew of 9.  Sawyer, blocksetter, sawman, yardman,two on the edger, two guys tailing and one running the slab saw.
Offline Buzz-sawyer
« Reply #83 on: January 04, 2004, 09:12:01 AM »
Sawyer40
A big part in doin a big day for us is...what we are cutting, and lately that has ben cross ties and the little 6x8 ones...makes a big difference on daily production!....Also we use conveyors for the slabs and the of bearer does not have to pick up the cants or boards to stack em..we use fork lift forks and lower them to a good working level as we go...so ya flip em on the pile (ties cants)
« Reply #84 on: January 04, 2004, 12:20:35 PM »
Buzz I know what you mean bigger beams really add the footage up quick. All my slabs  waste and cutoffs get shoved in a vibrating conveyer and disapear to the mulch grinder. We do the same thing you do with a forklift to get the lumber or beams out of the way. All the boards that need edging go down a set of rollers to a deck at the edger. If I have enough help we run the edger at the same time if not just pile the boards up on the deck and do it later
Offline Corley5
    • Whittaker Farms
« Reply #85 on: January 04, 2004, 01:36:26 PM »
I seldom saw anything other than 1 or 2 inch stuff.  I did saw some beams for a buddy a while back and it does make a big difference in output.  Way less cuts.  We usually pile up the edge boards next to the edger and run them later also.  What I like to do is saw in the morning,  finish up what's left on the deck if any after lunch, then edge, dispose of the slabs and sawdust and sticker lumber in the afternoon.  Sawdust goes into a manure spreader and is spread on the fields and slabs go on a dump trailer to be dumped outback for firewood or burnt where they lay.  Since I've got a rough terrain forklift now we're going to sticker as we go rather than handling everything again later.  Just pick up the banded stickered pile and put it where I want.
« Reply #86 on: January 05, 2004, 10:19:10 AM »
Recently I cut a lot of skid material 6x6 8x8 10x10 12x12 all 18-20-22' let me tell you there is a lot of footage in a 22' 10x10 or 12x12 you don't need to cut many to make 4 or 5000 ft
Corley any shortcuts in handling is a plus. Time is money!
Offline Buzz-sawyer
« Reply #87 on: January 06, 2004, 09:33:12 AM »
Looks like when your sawin you gotta cut bout19-20 of those 12x12 cants to get 5000 then after lunch 20 more...of course thats not countin side wood...that is another story...
  Dont get me wrong I am with you guys I like to save up my edgings till done openig up all the logs...
it is just a totally different task...different mind set,
A lot of the time in the past I would saw alone now that is some work...itll break ya but I still love it...hard to say why...but I LOVE making big sticks into little ones...maybe cause I gotta simple mind and I get into some kinda zone when sawing????
Don
Offline Buzz-sawyer
« Reply #88 on: January 09, 2004, 08:51:08 AM »
Did I kill this thread?!?!?!
Offline Stan
« Reply #89 on: January 09, 2004, 03:38:45 PM »
Yep you did it agin.  :-X
I may have been born on a turnip truck, but I didn't just fall off.
Offline DanG
« Reply #90 on: January 09, 2004, 07:27:52 PM »
NOOP!  Thread not dead. :)  I post some pretty dismal board footage figures. I have been sawing for the experience as much as for the lumber, so I have been taking my time with each log, and trying to maximize the recovery. Every little corner of each "slab" (what's that!  ???) gets converted into stickers or firring strips, so that my waste pile is almost non-existant. :)
However, that practice is going to be short-lived. I only have 10 more work days until I "retire", and have to rely on sawmilling and a couple other ventures to make my living.  Then it will be necessary to make my time count for $. There will be times when I don't have a lot to do, so the "training" I've been doing will help me maximize my per-log profits, but there will be busy times when I have to value my time more than the little bit of waste I'm generating. Learning to balance the two will be a challenge. I plan to take the whole transition log by log and board by board, and let the business go where it wants. I just hope it doesn't want to go into the dumper. ::)
Offline shopteacher
  • Hiking Sedona, AZ.
« Reply #91 on: January 10, 2004, 02:29:19 AM »
Well DanG, congratulations on reaching retirement ( unless Bush and the other government cronies decide that retirement age needs pushed back to 85 in the next ten days).  Guess now the real work begins.  Anyway here's to a long, safe, prosperous and happy retirement.  Old Butch says to sit back, relax, have one on him then get your a$$ out to sawing.
Offline OneWithWood
  • I am happy!
« Reply #92 on: January 10, 2004, 05:14:05 AM »
The next few days are going to fly by!  Best of luck to you with your ventures.  Looking forward to following your adventures.  Now that you will be sawing as a business the trip up to the piggy roast could become a legit business expense  8)
One With Wood
Offline Frank_Pender
« Reply #93 on: January 16, 2004, 08:14:44 AM »
Dang, ther is another one of us retired folks makeing sawdust. 8)  8) 8) 8) Well done Dan G. ;D  I hope you enjoy your retirement as much as I do.  With my three Mobile Dimension Mills.   :P
