Author Topic: black spruce log won't cut  (Read 1460 times)
Offline 47sawdust
« on: May 24, 2015, 08:24:14 AM »
So.....I've been sawing a mixture of Vermont softwoods,black spruce and balsam.Running 4░blades and everything is going fine..I was feeling real good because all I have on my land is black spruce,with a little pine,hemlock,and balsam.The very last log in the yard was what appeared to be a nice 15'' spruce.Entering the log from the butt end the first cut was wavy,put on a new blade same results,adjusted the drive belt tension,1st cut wavy,2nd cut blade dives and binds.The mill has less than 500 hrs.
 I'm curious why things would go from very good to very bad so fast.I'm off to cut a more friendly tree to see if that helps.
Anybody had a log that wouldn't cut?
 Thanks and Happy Memorial Day,
Mick
U.S.Army 1966-1968 riot control duty
Mick
Offline Logger003
Re: black spruce log won't cut
« Reply #1 on: May 24, 2015, 08:40:38 AM »
No expierence with a band mill but black spruce on the circle saw causes all kinds of trouble to. It likes to pinch the saw blade, it seems like there's a lot of stress in that type of wood
Offline red
  • we will never forget
« Reply #2 on: May 24, 2015, 09:03:02 AM »
Yes try another log.  . Some have good luck with pinesol in the water
Also HP and feed rate
Offline justallan1
  • living and learning
« Reply #3 on: May 24, 2015, 09:16:27 AM »
If it's anything like spruce out of the PNW it's mainly a matter of soft wood and hard knots.
When running a re-saw in commercial cut-up mills I'd get SPF units of wood and found it was actually faster to set the spruce aside as I would find them, run the pine and fir, turn my feed rollers down and run the spruce nice and slow. It cut down production a little, but was the only way to make it sellable.
Offline drobertson
« Reply #4 on: May 24, 2015, 09:34:30 AM »
This might be a pain in the rear, but if at all possible pull the log off and flip it around, coming in on the small end,  I've seen issues with some larger pine when coming in from the butt end, mainly humping up, then leveling out,,  I've only sawed a few Norwegian Spruce, these were a little bigger but not by much, yard trees, they sawed out pretty good, the wood seemed very hairy though, not a smooth finish like you get from most pine.  The knots were no problem, but not near as pretty as I was hoping for.
Offline GAB
« Reply #5 on: May 24, 2015, 04:34:01 PM »
Mick
Dear Fellow Vermonter:
You have pretty much described my experience with Colorado Blue Spruce.
I recently posted asking for suggestions on how to saw it because of my past experience with CBS.  Just picked up 5 decent 12 foot logs.
As an aside I've sawed some Norwegian spruce, and red spruce with no problems.  I usually saw going into the small end because of the way branches grow on trees.
Based on the suggestions I received to my post and from what I've read on the forum I'm going to take a 9* 7/8" tooth spacing blade and reset it for .030" to a side and try that.
If that does not work I may try to get a 10* to 13* blade with a 3/4" tooth spacing to try.
You wrote: "U.S.Army 1966-1968 riot control duty"
Were you in Detroit during the riots with Sgt/Mjr. Kidwell?
Gerald  (West & North of you)
Offline 47sawdust
« Reply #6 on: May 24, 2015, 04:43:14 PM »
GAB,
Thanks for your reply as well as the others.Fresh pine logs are on the log deck,but BBQ takes precedent this afternoon.
I was in Washington D.C.for the race riots after MLK was killed,also at the Pentagon for the 1967 peace demonstration.It was a very strange time in our nations history.
I am going to turn the problem log end for end as suggested and see what happens.All advice is greatly appreciated.
Thanks,
Mick
Mick
Offline VTwoodworker
  • I drive a LT30
« Reply #7 on: May 24, 2015, 08:51:09 PM »
Hi Mick,
First thanks for your service and Happy Memorial Day to you and all Vets on this board.
Second I have cut quite a bit of spruce in the last few years and I have come across a few like you describe.  At times the blades just want to follow the grain particularly when the growth rings are large.  I have had the best luck cutting spruce with WM double hard 0.045" 9 deg blades.  Stop over and I will let you have one to try on that log.
Gotta love milling spruce.
Wayne
Offline Ox
  • Trying to learn/remember something new every day.
« Reply #8 on: May 24, 2015, 10:58:14 PM »
I must say that I seldom hear anything good when talking about milling spruce.
Offline barbender
« Reply #9 on: May 25, 2015, 12:45:09 AM »
I've had spruce make waves, but the only time I've ever had a blade dive bad enough to bind was when I got pitch built up on the blade really heavy.
black spruce- white spruce how to tell
Started by northernss454 on Tree, Plant and Wood I.D.
Last post June 05, 2022, 09:07:11 AM
by SwampDonkey
Black Spruce
Started by Thefarmer76 on Ask The Forester
Last post September 27, 2015, 07:51:54 AM
by Thefarmer76
Black Spruce Seedlings
Started by Billbob on Tree, Plant and Wood I.D.
Last post May 25, 2015, 07:51:37 PM
by OntarioAl
black spruce T&G flooring
Started by Quebecnewf on Drying and Processing
Last post February 11, 2012, 06:29:47 AM
by Quebecnewf
