Finally installed a Lubemizer
Started by dogbo2013, May 05, 2024, 07:20:46 AM
dogbo2013
After struggling with choosing the right lubricant for years, I finally upgraded my LT40 with a Lubemizer setup. Pine has always seemed to be the biggest offender and causes me the most issues with pitch build up. I have been able to deal with it using water and cotton picker spindle lube, but I would go through 1.5-2 tanks of lube a day. I have always hated the amount of water it put on the wood and mill, but it was the only thing that would effectively cut the pitch. Now I am running diesel only and using very little. It cuts the pitch with ease and I am using about 2.5 gallons for every 40 hours of cutting. Based on recommendations from others on this forum, I plugged the bottom hole on my guide block and only use the sprayer on the top of the blade.
GMB
That is a sorta expensive upgrade but worth every penny.  :thumbsup:
I mostly saw Pine but I have not made the switch to Diesel yet.  When I see any blade buildup, I switch to continuous for probably 5 seconds and then back to pulse.  My 5 gallon jug easily last a couple of weeks.
My mix is a glug (about 2 oz.) of original liquid Cascade per gallon of water.  I found that even the spindle lube that I was using made suds while mixing and Cascade does not.
ladylake
 Back when I was using soap and water I used the same as dogbo 1 1/2 or 2 jugs a day.  Good move switching to diesel, now you can honestly use a quart or 2 a day.  Steve
TimW
Quote from: Magicman on May 05, 2024, 07:40:32 AMThat is a sorta expensive upgrade but worth every penny.  :thumbsup:
Lynn,
       I use Dawn dish soap.  Works fine for me.  But it does make lots of suds upon mixing.  I'll try Cascade next fillup.
Get the Cascade in the light green jug.  I remove the white squirt cap so it will glug.DSCN0302
DSCN0306
One glug (about 2 oz) per gallon.
fluidpowerpro
I have had good luck using pine sol (or generic equal) that I get at the dollar store. It's cheap enough I can use it generously. I put it in after the water so it don't suds up.
Change is hard....
