Author Topic: Instructions how to sharpen blades with CBN  (Read 554 times)
Offline MobileSawMilSlo
  • New owner just learning and working
    • Mobilna zaga - Slovenia
« on: June 08, 2018, 06:15:20 AM »
Hi guys
Does someone have maybe instructions how to properly set CBN sharpener (like BMS 500) and how to configure everything as you should.
For example ... how much the blade should be raised, hot to tell that CBN is touching face of the blade at exact spot, how many cycles should you do it per blade etc.
I know few things from looking video, but I did not find good instructions about it.
I am still searching for an answer why does it see and hear, that grinder touches blades 2 times per "cycle"? I also see 2 "sparks" in a cycle and I do not understand why this happens.
For example look here:
How to Sharpen Bandsaw Blades - Wood-Mizer BMS500 - SE Metals - YouTube
Thank you.
Woodmizer LT20 mobile and TTP-600 Premium Plus
DAJK - all sawing equipment in one place
Offline MartyParsons
  • Wood-Mizer Service and sales PA, VA, MD, WV others
Re: Instructions how to sharpen blades with CBN
« Reply #1 on: June 08, 2018, 08:51:54 AM »
I sent you a message.
Marty
A pessimist sees difficulty in every opportunity; an optimist sees opportunity in every difficulty. -Winston Churchill
Need someone to sharpen blades in Louisiana
Started by kip on Sawmills and Milling
Last post July 05, 2003, 03:17:22 PM
by JoeyLowe
were can i get band saw blades sharpen
Started by 44woody on Sawmills and Milling
Last post April 01, 2013, 11:36:16 AM
by 44woody
here is how I sharpen my mower blades!
Started by doc henderson on General Board
Last post May 23, 2020, 05:46:50 PM
by Tom King
Anyone Sharpen their own planer blades?
Started by Cypressstump on General Woodworking
Last post February 14, 2013, 12:49:50 PM
by terrifictimbersllc
