Instructions how to sharpen blades with CBN
Started by MobileSawMilSlo, June 08, 2018, 06:15:20 AM
MobileSawMilSlo
Hi guys
Does someone have maybe instructions how to properly set CBN sharpener (like BMS 500) and how to configure everything as you should.
For example ... how much the blade should be raised, hot to tell that CBN is touching face of the blade at exact spot, how many cycles should you do it per blade etc.
I know few things from looking video, but I did not find good instructions about it.
I am still searching for an answer why does it see and hear, that grinder touches blades 2 times per "cycle"? I also see 2 "sparks" in a cycle and I do not understand why this happens.
For example look here:
How to Sharpen Bandsaw Blades - Wood-Mizer BMS500 - SE Metals - YouTube
Thank you.
Woodmizer LT20 mobile and TTP-600 Premium Plus
DAJK - all sawing equipment in one place
MartyParsons
