Author Topic: Sawing/Drying Holly  (Read 793 times)
Offline pinehillstacker
Sawing/Drying Holly
« on: June 14, 2019, 08:53:36 PM »
I have a hundred or so bf of holly logs that I cut down not long ago.  From what I've read, that was the wrong time of year to cut it, but the holly trees were in the way of a building project, so I didn't have a choice.  Getting ready to saw it and have a couple questions for you guys.  I was planning to saw 1" boards.  I don't know how holly dries as far as checking, staining, etc.  Will 1" boards dry ok?
I have a kiln lined up to put the lumber in directly after I saw it, but the guy running the kiln has never done holly before.  Are there any tricks to get it to dry right?  Does it need extra stickers, or slower/faster drying?
Thanks in advance,
Si
Lonely Oaks Timber - custom sawing, logging
Offline Ianab
Re: Sawing/Drying Holly
« Reply #1 on: June 15, 2019, 02:06:01 AM »
The trick seems to be to get it dry ASAP after the tree is cut. The wood soon loses it's white colour that makes it special, and goes a boring grey.
I don't think there are any special drying issues, just time.  The cooler temps in winter slows the greying process and means you have more time between cutting and drying, which makes life easier.
Offline kelLOGg
« Reply #2 on: June 15, 2019, 06:46:32 AM »
Here's my experience with kiln drying holly too late.
HOLLY in Sawmills and Milling
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #3 on: June 15, 2019, 07:35:46 AM »
If the logs have been cut for a while, it probably has already gray stained some.
Woodmizer LT40HDD35, John Deere 2155, Kubota M5-111, Nyle L53 Dehumidification Kiln, and a passion for all things with leafs, twigs, and bark.  hamsleyhardwood.com
« Reply #4 on: June 17, 2019, 05:53:10 PM »
Thanks everyone, sounds like I may have missed the boat, but going to saw it out anyways and see what happens. 8)
Drying Holly
Started by Woodwalker on Drying and Processing
Last post December 27, 2008, 10:39:19 AM
by Den Socling
Drying Holly
Started by Rwill114 on Drying and Processing
Last post October 21, 2021, 09:03:06 PM
by scsmith42
Drying Holly.
Started by The WoodYard on Drying and Processing
Last post January 02, 2014, 12:14:28 AM
by WDH
Sawing Holly Logs
Started by Ga_Boy on Sawmills and Milling
Last post January 01, 2005, 01:17:03 PM
by Curlywoods
