Cutting Stickers
Started by High_Water, July 20, 2021, 08:55:41 AM
GAB
Quote from: Larry on July 21, 2021, 05:17:40 PM
I betcha YH makes em out of curly maple.  He's just not showing us his good ones!
Funny that you should mention curly maple because on wednesday 7/21/21 I Q'sawed 2 curly maple logs for a customer for guitar necks.  Took a while but he seemed to be happy.
GAB
teakwood
My stickers are made out of teakwood.  :D ;)
Nebraska
Crusarius
pretty sure your firewood is also made of teak :)
Joe Hillmann
I have found making stickers out of scraps isn't worth it.  I usually sand up 5 or so perfect boards(no knots, no bark, straight grain) on the mill and cut them into 1 inch strips, then cut their length to my stack width.
It feels like a waste of good boards but I reuse them many times over and having stickers that don't fall apart under their own weight and that can be kept tidy when not in use and being able to reuse them many times over make it lest wasteful in the long run.
moodnacreek
I  have no use for planed stickers. The rougher the better if you can't  have profiled .
Al_Smith
I went around and got dunnage boards from a couple of lumber yards ,freebies .Set up my table saw and cut them down to 3/4" stuff ,all 4 feet long .I had a couple of paper barrels full at one time. They are pine of course but they must have worked because the air dried lumber seems to be okay .There isn't any sticker stain on the oak, ash ,walnut or black cherry lumber I've seen .
YellowHammer
Here's what I use.  I've got a few bins of them, including the ones being used.  These are about $1 each and work better than anything I've used, including the composite ones.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Al_Smith
I've never used them but have heard of using 3/4" PVC pipes for stickers .I did however once cut rollers from 2" PVC pipe and used them to roll an 1800 pound Bridgeport model M milling machine about 50 feet to put it in place .This stuff is stronger than you might think .
moodnacreek
Quote from: Al_Smith on July 25, 2021, 07:11:07 AM
Those woods don't count. It's sugar maple, elm. clear white pine, tulip and other 'white' woods that the stickers can ruin.
moodnacreek
Y.H., send me up a t/l of those twisted sticks :D. You sure are professional and no kidding here.  I have herd that those sticks will impress w.pine but they have to be the way for most any other wood.
Andries
Quote from: moodnacreek on July 25, 2021, 10:17:47 AMY.H., send me up a t/l of those twisted sticks :D. . . .
@Yellowhammer are those twisted stickers the same that @customsawyer had a one of the projects?  If I remember right, Jake had a bunch of sticker bundles from the Beasley mill - they will only allow so many cycles through the kiln with their stickers.
I helped you load a whack of them into your truck and that was the first and only time I'd seen that style.
LT40G25
Ford 545D loader
Stihl chainsaws
customsawyer
The stickers I got from Beasley's were broken and no longer fit there stacking machine. They run 6 ft. packs and the machine has small C channel for the sticks to slide in. So if they break on the ends they no longer reach to the C. Well this makes them great for my pallets at 4 ft.
www.thecustomsawyer.com
alan gage
Quote from: Al_Smith on July 25, 2021, 07:59:22 AM
Better band those packs tight before you try to move them. :)
Alan
YellowHammer
These are similar to the ones from Customsawyer, but we use so may now, that we just order these directly from the manufacturer.  We buy them by the "1,000 pc cube" and have replaced all of our conventional and H style stickers with them.  These allow me to dry sticker stain prone wood, such as poplar, even during the summer months.
On some softwood and hardwoods, as moodnacreek says, if the packs are stacked too high, the limited contact area will crush the surface fibers on the face of the boards, and will be visible. However, as long as the stacks are not more than 10 feet high, (in our experience) they won't crush the surface fibers and isn't a problem.  However, with big commercial mills, and when stacking sky high, it can be significant.  The nice thing is that fibers crushing by "sky high stacking" can be mitigated by simply adding extra stickers per row, which brings down the individual contact loads, and eliminates fiber crushing.
We dry very soft woods using these, such as basswood and pine, and as long as the stack height is watched, no problems at all.
The absence of any sticker stain is really a nice stress reliever for me, especially in the summer.  Many mills in this area won't even saw and dry maple, poplar, basswood and other white woods because of the chances of sticker stain in the hot summer.  So this gives us an edge, and we don't have to be so "seasonal" when we are sawing white woods.
YellowHammerisms:
Al_Smith
Quote from: moodnacreek on July 25, 2021, 10:11:24 AM
Now a question because I really  don't know as I have none of those "white woods " .Generally speaking the rough lumber would be 1" thick and then planed down to say 3/4".Does  the planning remove the sticker stain ?
moodnacreek
Sawing and drying white woods in hot weather must be strictly controlled from the stump to stored dry lumber.  I am a rather rough mill with no kiln and mostly outdoor storage.  Low grade softwood for 1x12 rough, a.d. and oak trailer plank in any condition is my main thing. Most lumber sold here is sold off sticks. However as the area changes from country to city the loggers are gone and the logs come from tree service. [a chosen few operators]  So high grade sometimes lands here and i was reselling it until covid.  I have proved after past failures that I can air dry hard maple without sticker shadow not that anybody wants it but I pride myself with at least knowing how to do things right like if I can't sell the logs and must saw them. Same goes for clear white pine even though many think it is cute. Funny how customers cull the blue stained boards.
YellowHammer
There are several types of sticker stain, and it varies with the species of wood, and whether it manifests in the heartwood or the sapwood, or both. There is also mold stain as well as enzyme stain.
Oaks for example, will come down with a dark streak stain, generally caused by mold and insufficient airflow, either air drying, or in the kiln.  Its is generally only a few fibers deep and easily planes out.  Its will get worse deeper in the stack, and sometimes can become a problem in the sapwood of some species, such as white oak and hickory, where it won't plane out, although it will plane out in the heartwood.  So when this happens, the solution is to edge off the sapwood, or better yet, don't let it happen in the first place.
In some species, using too dry of a sticker will cause reverse sticker stain, or white streaks, and I've seen it go deep enough to take a couple passes to plane out, which can be a pain.  I generally see this in cherry or or sassafras, or other mildly shaded wood species.  So I cycle my stickers and don't use just out of the kiln stickers for green off the mill wood.  I'll let them air acclimatize in a bin and get to them after awhile.
The absolute worst, and generally the most common in "whitewoods" is enzyme stain.  It can show up as black streaks under the stickers, or as white streaks because the rest of the white wood has turned gray.  This enzyme stain almost always shows up in warm to hot weather, either outside while air drying or in the kiln.  Basically, the sugars in the wood get too warm and begin to discolor, and this "gray stain" will go completely through the wood, and can't be planed out.  Sometimes it even gets worse the deeper the wood gets planed.  This is some bad stuff, and will ruin entire packs of wood.  Sometimes it will even be so bad, its will look like "zebra stripes."  Some big mills even have this problem.  It has different stages, and spiral stickers will help in the initial stages, but the conditions are completely wrong, then nothing will help.  In a kiln, the general rule of thumb is a 20 degree WB/DB separation, with air flows up in the 400 feet per minute range.  When air drying, fans blowing over the stacks will really help, as it evaporates surface water and also helps keep the stacks cool.
Sticker stain in professionally kiln dried wood is a litmus test.  When I purchase packs of wood from others, (I sometimes can't keep up with sales) then I will always grade them on their ability to dry "clean and bright."  I just had a pack of poplar that I sent back to a relatively well known manufacturer because of some enzyme stain.  It was a swing and a miss.
YellowHammerisms:
moodnacreek
Quote from: Al_Smith on July 25, 2021, 04:37:22 PM
In the case of hard white maple it will not plane out for sure. All 'white woods ' are touchy.
farmfromkansas
I have had ash get sticker stain.  My sticks are scraps from the wood shop, boards never work out full width.  Haven't gotten into shaping the sticks.
