Author Topic: Shrinkage  (Read 576 times)
Offline Crossroads
  • letís make some sawdust
    • Kevin Bales faith family farm and portable sawmill
Shrinkage
« on: August 02, 2021, 12:08:57 AM »
I ran a bunch of 2x through the edger a few weeks ago and didnít measure any of it to verify that it was coming out at 7 1/4Ē wide. A couple days ago I was walking by and happened to throw a tape on it. To my surprise it ranges from 7Ē to 7 1/8Ē. The wood is Doug fir. Iím just now starting to mess around with drying and processing, is a 1/4Ē of shrinkage to be expected on a 2x8? Next time I set the edger up, Iíll definitely be checking whatís coming out of it.
2017 LT40 wide, Kubota l185dt, 2-036 stihl, 2001 Dodge 3500 5.9 Cummins, l8000 Ford dump truck, hr16 Terex excavator, Farmi logging winch, Valley je 2x24 edger, Gehl ctl65 skid steer
Offline customsawyer
    • The Custom Sawyer
Re: Shrinkage
« Reply #1 on: August 02, 2021, 06:33:27 AM »
I've never sawed Fir however that much and maybe a little more shrinkage would be in line with SYP. Might be a little quick but this time of year it can happen.
Two LT70s, Nyle L200 kiln, 4 head planer, 30" double surface planer, Lucus dedicated slaber, Slabmizer, and enough rolling stock and chainsaws to keep it all running.
www.thecustomsawyer.com
Offline scsmith42
    • Whispering Pines Farm
Re: Shrinkage
« Reply #2 on: August 02, 2021, 06:50:33 AM »
Doug fir shrinks between .0015 (radial) to .0026 (tangential) per inch of width, per percent of moisture reduction.  So for structural use, it will lose around 14%MC  drying from 30% MC to 16% MC.
So a 7.25" wide board will shrink at most 7.25 x (.0015 or .0026) x 16, or between 3/16" to .300" in width as it dries.
So your results sound about right to me.
Tom's 3638D Baker band mill
Offline bannerd
  • Madman
Re: Shrinkage
« Reply #3 on: August 02, 2021, 07:24:28 AM »
What about shrinkage end to end or does that not ever happen?
Offline Ianab
Re: Shrinkage
« Reply #4 on: August 02, 2021, 07:37:46 AM »
Usually so small that it doesn't matter.
There is some slight lengthwise shrinkage in wood as it dries, but it's about 100X less than the cross grain, so we tend to ignore it.
Offline Don P
    • Calculator Index
Re: Shrinkage
« Reply #5 on: August 02, 2021, 08:23:06 AM »
The exceptions to that are juvenile wood and reaction wood. Those fibers do shrink in length as they dry and are the force at work behind a number of drying warps.
The juvenile wood on the upper face of this board shrinks in length as it dries, bowing the piece. Enough length shrinkage that it sheared 2 deck screws.
The future is a foreign country, they will do things differently there - Simon Winchester
Offline Crossroads
Re: Shrinkage
« Reply #6 on: August 02, 2021, 08:57:27 AM »
Thank you, Iím actually pretty surprised that it would shrink that much. One more lesson from the school of hard knocks in the books. Fortunately I have a project at home that I can use it all up. I believe Iíll be spending a lot more time on this section of the forum. Thank you again!
Online Southside
    • White Oak Meadows
Re: Shrinkage
« Reply #7 on: August 02, 2021, 09:18:57 AM »
The shrink sounds right  - but as you said, you don't know what you were actually set up to cut, so hard to say.  I know on my edger there are two brass wear rods that hold the adjustable blade in place for fine adjustment and weekly I need to bump them in ever so slightly due to the brass doing what is was designed to do.  Only takes a minute if that, but if I don't the adjustable blade would fall out of alignment with the the indicator and my output would not be what I thought it was going to be.
White Oak Meadows
Offline bannerd
  • Madman
Re: Shrinkage
« Reply #8 on: August 02, 2021, 10:53:04 AM »
Good info here, Thanks!
Offline Crossroads
Re: Shrinkage
« Reply #9 on: August 02, 2021, 03:45:37 PM »
Sounds like I have been putting to much trust in my edger. I plan on swaps the blades out as soon as I get time. That should be an adventure
Online Southside
    • White Oak Meadows
Re: Shrinkage
« Reply #10 on: August 02, 2021, 04:13:22 PM »
Not really - it's a tool and now and then you need to calibrate and maintain it.  Just like the scale on the mill can get off.
White Oak Meadows
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Shrinkage
« Reply #11 on: August 02, 2021, 04:21:37 PM »
Just round figures but when sawing framing lumber; on 4 & 6" I oversize 1/8", on 8 & 10" I oversize 1/4", and on 12" I oversize 1/2".   The key word is being consist.
Note that there can be a significant difference between sawing fresh felled and 'old' logs.  You can expect more shrinkage plus stress in fresh felled which is why I prefer to saw 'old' bark slipped SYP logs.
Offline Crossroads
Re: Shrinkage
« Reply #12 on: August 02, 2021, 07:39:35 PM »
All good info, thank you!
Offline YellowHammer
  • Sawing is fun for the first couple million boards.
    • Hobby Hardwood Alabama
Re: Shrinkage
« Reply #13 on: August 02, 2021, 09:26:02 PM »
There's enough shrinkage in wood that the Hardwood Market Report (the gold standard for wood prices) has different specs for "green off the mill" and "kiln dried" due to the amount of shrinkage and volume loss.
YellowHammerisms:
Take steps to save steps.
If it wonít roll, its not a log; itís still a tree.  Sawmills cut logs, trees.
Kiln drying wood: When the cookies are burned, theyíre burned, and you canít fix them.  So donít burn the cookies.
Sawing is fun for the first couple hundred boards.
Offline Crossroads
Re: Shrinkage
« Reply #14 on: August 02, 2021, 11:49:26 PM »
I ran some 1x through the edger today and they were all 1/16th over, so Iím either looking at shrinkage or I done messed up on my edger settings. I guess 2x8ís will be getting an extra 1/4 from now on.
Shrinkage...
Started by mrcaptainbob on Sawmills and Milling
Last post March 23, 2010, 04:50:52 AM
by SwampDonkey
shrinkage
Started by vfauto on Sawmills and Milling
Last post December 07, 2011, 07:46:32 PM
by red oaks lumber
SYP shrinkage
Started by Jimbob on Sawmills and Milling
Last post November 27, 2008, 07:37:56 PM
by backwoods sawyer
shrinkage
Started by fuzzybear on Drying and Processing
Last post March 26, 2013, 10:57:59 PM
by Jay C. White Cloud
