Author Topic: Bought a used edger  (Read 817 times)
Offline boonesyard
  • I've got a little sawdust in my pocket
Bought a used edger
« on: August 10, 2021, 11:49:23 AM »
Been looking at edgers for some time. Would have liked to have gone new, but the time frame for delivery is way out there with all of them, and what I want and what I can afford have some space between them  :)
Found a used Riehl edger with no engine. I think we made a decent deal on it today, should have it in a week or so. I'll need to put a power plant on it, will have to be gas engine as we don't have 3 phase.
Looking for some recommendations on an engine. Looking at a few used options, one being a 20hp Honda GX620, said it came out of a small skid steer. I see you can get a new Riehl with a Honda GX630, that engine new sells for about $1,600. Would need an ignition switch, battery and gas tank as well. I see a new Predator 22hp is $900, comes with the switch. Looks like that Honda engine turns 4000 rpm at its max, so I guess that would be the target? Thoughts?
Really looking forward to getting an edger up and running.
LT50 wide
iDRY Standard kiln
JD 4520 w/FEL
Cat TH255 Telehandler
lots of support equipment and not enough time
"I ain't here for a long time, I'm here for a good time"
Offline Southside
    • White Oak Meadows
Re: Bought a used edger
« Reply #1 on: August 10, 2021, 02:51:36 PM »
I have a Kohler CH730 on mine - runs awesome.  Only issue I had was a little bit ago when the carb developed some sort of issue. $8 carb rebuild kit solved that - so can't complain.
Call Darin and ask him for the input speed specs based on the lower driven pulley that is on it.
White Oak Meadows
Offline alan gage
« Reply #2 on: August 10, 2021, 03:10:13 PM »
I've had the 22hp Predator on my mill for the last couple years with no issues. Not saying it's the best but it sure was the most convenient when my motor suddenly died. Three hour round trip to Mankato in the morning and back to sawing same day.
Alan
Timberking B-16, a few chainsaws from small to large, and a Bobcat 873 Skidloader.
Offline boonesyard
« Reply #3 on: August 10, 2021, 04:19:59 PM »
Been reading engine specs till I'm bug eyed. Looks like any of them would work, quit a difference in price between the Predator and the others (Kohler, Honda, Briggs Vanguard). All of the specs read about the same, It'll be interesting to see what the availability is, haven't checked any of them yet. One thing I noticed about the Predator is a lot of reviewers say to replace the pulse fuel pump and spark plugs right away. Decisions, decisions
LT50 wide
iDRY Standard kiln
JD 4520 w/FEL
Offline Larry
    • Copas Sawmill
« Reply #4 on: August 10, 2021, 04:34:21 PM »
If you have electricity, this might be the time to go 3 phase generated by a phase converter.  Far cheaper and more reliable than an engine.  If you can source used 3 phase motors and buy a converter kit the up front cost could also be cheaper.
Offline boonesyard
« Reply #5 on: August 10, 2021, 05:06:57 PM »
I'll check on that as well, thanks
LT50 wide
iDRY Standard kiln
JD 4520 w/FEL
Offline Southside
    • White Oak Meadows
« Reply #6 on: August 10, 2021, 05:26:48 PM »
That Predator is a Chinese knock off, after everything over the past year and still happening that's a factor to consider.
White Oak Meadows
Offline boonesyard
« Reply #7 on: August 10, 2021, 09:19:33 PM »
So,,,, I got home tonight and was bucking logs when had an epiphany. I have a 30 yr old John Deer F935 diesel mower I bought for parts a couple years ago to supplement our good 935. The hydraulic pump is out of the parts mower, but I had the engine running last year. It's a 22hp 3 cylinder liquid cooled Yanmar, they're just about bullet proof, and it's a horizontal shaft ;D. With a little fab time, new filters and some TLC, I think this thing will work very well on that edger. The juices are flowing, I'm jacked!
LT50 wide
iDRY Standard kiln
JD 4520 w/FEL
Offline Southside
    • White Oak Meadows
« Reply #8 on: August 10, 2021, 10:34:53 PM »
Umm - I think it will kick butt on that edger!!!
White Oak Meadows
Offline Crossroads
  • lets make some sawdust
    • Kevin Bales faith family farm and portable sawmill
« Reply #9 on: August 11, 2021, 09:26:28 PM »
Sounds like a great combination!
2017 LT40 wide, Kubota l185dt, 2-036 stihl, 2001 Dodge 3500 5.9 Cummins, l8000 Ford dump truck, hr16 Terex excavator, Farmi logging winch, Valley je 2x24 edger, Gehl ctl65 skid steer
Offline Percy
  • Resident trouble maker
« Reply #10 on: August 11, 2021, 10:13:43 PM »
Excrement!!! Haha spell check is hilarious. Excellent is what I had in mind. That diesel will be great and stingy to operate. 👍👍
Offline boonesyard
« Reply #11 on: September 10, 2021, 11:46:33 AM »
The edger showed up, yippee. Looks to be in about the condition I was expecting, and hoping. It's an early model from Riehl, but the frame is straight, main saw shaft and bearings are good, feed rollers still have a good edge to the stippling and bearings are good. Gear reduction is in very good condition. The adjustment wheel works, but the adjustment shaft had brass bushings on both ends that are wore out.
I'm impressed with the simplicity and standardization of this machine. All sizes, nuts, bolts, bearings, bushing are all standard sizes and very available. I gave Darin a call at Riehl and he was extremely helpful, great guy. The infeed bed rollers are wore out and he has the direct replacement or an upgrade with side bearings for new rollers, I ordered 3 upgraded sets. He's also sending me 2 additional bearings (same size 3/4") for the adjustment shaft instead of replacing the brass bushings.
These are the parts that make up the adjustment fork that captures the sliding collar for the movable blade, obviously wore out, but Darin had them in stock.
Two of the 3 gear reduction pulleys off the main saw shaft for the feed adjustment. They wer busted, had to cut them off, but Darin had these in stock as well, very impressed with the availability of the parts.
LT50 wide
iDRY Standard kiln
JD 4520 w/FEL
Offline boonesyard
« Reply #12 on: September 10, 2021, 11:49:14 AM »
Ooops, hit the post button too soon.
Busted pulleys
We've got it all apart, now we're wire wheeling all loose paint, and will prep and repaint with POR 15. Still considering motor options, should have it figured out soon.
LT50 wide
iDRY Standard kiln
JD 4520 w/FEL
Offline Southside
    • White Oak Meadows
« Reply #13 on: September 10, 2021, 01:55:43 PM »
Well the older design looks to be exactly the same design as mine.  I believe Darin told me once that his grandfather had first began to produce these.  On the forks, keep some of the brass insert stock on hand, it does wear out as it should and needs to be pushed in from time to time to keep the moveable blade accurate.   Other than regular lubrication and cleaning it out they are pretty maintenance free machines.
White Oak Meadows
Online moodnacreek
  • Sawin by the notches
« Reply #14 on: September 10, 2021, 02:37:52 PM »
The shift collar parts wear out often on the light duty edgers. Over time the shift hub and mandrel also. It's all part of the game. I have seen men make their own saw shifter using 2 wooden pigs that push against the saw itself. This rig is almost like a circle saw guide that moves on an arm.
just bought edger ?
Started by customdave on Sawmills and Milling
Last post May 02, 2013, 01:47:19 AM
by Brucer
Bought a used edger
Started by Randy88 on Sawmills and Milling
Last post July 25, 2019, 03:46:20 AM
by Randy88
Finally bought a mill! Bought a Wood-Mizer LT10
Started by Schramm on Sawmills and Milling
Last post February 18, 2013, 10:10:40 AM
by Happycamper
Edger
Started by ahlkey on Sawmills and Milling
Last post December 18, 2011, 12:33:25 PM
by sdunston
