Author Topic: drying Bass Wood  (Read 351 times)
Offline Charles
drying Bass Wood
« on: August 31, 2021, 10:06:12 AM »
I have been trying to dry some 5" thick bass wood that has been air dried to about 14%
My kiln holds about 800 bd/ft and I use the Nyle L50 system. My moisture meter is a Delmhorst with the slide hammer attachment
I have the dry bulb set to 105 f and cannot get the wet bulb  to get past 88 while the MC inside the kiln is about 45%
I have tried raising the temp to 115 f in which case the wet came up to 100 so I set the wet to 95 but as soon as I turned on the compressor the wet side dropped within hours to 95 and the compressor never did come back on.
I did try the wet to 120 f but same results
Is thick bass wood slow and hard to dry or am I missing something.  I did have a load of 10/4 bass wood in before this with no  problem.
Right now the wood is losing about .3 % of moisture per day with the compressor off.
I have been drying a very long time and have never encountered anything like this
I am stumped, any suggestion's
Offline K-Guy
    • http://www.nyle.com/
Re: drying Bass Wood
« Reply #1 on: August 31, 2021, 10:45:14 AM »
At that thickness it will be very slow to dry. A general rule to use is to multiply your drying time by 2.5 by each inch over 1"
Nyle Kiln Sales & Service
"He has all the virtues I dislike and none of
 the vices I admire." -Winston Churchill
Bass wood & R R ties
Started by goose63 on Sawmills and Milling
Last post July 25, 2014, 06:44:29 AM
by Peter Drouin
Need help on drying wood for a sawing/drying shed
Started by Jeremy2200 on Drying and Processing
Last post May 21, 2011, 10:54:53 PM
by PineNut
Air drying, shed drying, oak drying and maple drying free Webinars
Started by GeneWengert-WoodDoc on Drying and Processing
Last post August 19, 2020, 07:41:18 AM
by Stephen1
pond bass
Started by Don_Papenburg on FOOD! FOOD! FOOD!
Last post October 13, 2010, 10:58:50 PM
by pappy19
