Author Topic: Woodland Mill HN 126 with 14 HP engine the drive belt rolls kicking the blade  (Read 365 times)
Offline FarmerRon72
  • Member*
I have had my Woodland Mill HM 126 with a 14 HP engine for about 2 months. It has been working great until it was cutting wavy boards. So, I found out that the blade guides were lifted and out of spec made the adjustments and was cutting better and then started the waves again. I looked at my belts and noticed that the blade was resting on the band wheels drive and follower. So, I decided to replace the belts. Once I completed the belt replacement and adjusting the drive belt to 1/4" deflection I reinstalled the blade and ensured the blade guides were set correctly. The blade is under 25 ft/lb of torque rotated the follower wheel by hand everything seemed correct started the mill up and ran it for about 20 secs and the blade popped off the drive wheel towards the back. I thought it was a blade adjustment issue so sent a tech support email at Woodland Mills they got back to me right away with additional procedure on adjusting the drive and follower wheel that isn't in the operatorís manual. Today I made the adjustments to the drive and follower wheels with no change with the belt issue. I notice that the drive belt rolls from the tensioner pulley to the drive wheel, which kicks off the band blade to the back on the drive side. Any ideas or suggestions would be great.
v/r
FarmerRon72
RSS
Offline maple flats
  • Life is what you make it!
    • cnymaple.com
I think it's always best to ask tech support , again.
Offline leeroyjd
Were your blade guides loose and backed away from blade before you made tracking adjustment?
Belt drive from engine to blade pulley
Started by Grower on Sawmills and Milling
Last post January 08, 2010, 05:50:27 PM
by eamassey
old lt 40 onan engine drive belt question
Started by Polly on Sawmills and Milling
Last post March 16, 2008, 11:00:35 PM
by MartyParsons
Flat belt circle mill drive ???
Started by backpacker on Sawmills and Milling
Last post November 12, 2019, 09:57:50 AM
by backpacker
LT40 drive belt jumped over, only half of belt on pulley.
Started by Delawhere Jack on Sawmills and Milling
Last post June 10, 2014, 08:20:25 PM
by woodmills1
