Author Topic: WoodMizer lt35 HD Feed Control Knob  (Read 393 times)
Offline widetrackman
« on: September 13, 2021, 01:14:27 AM »
My feed control knob (rheostat) is as loose as a goose, no resistance. I believe a strong breeze would move it while milling. When you are trying set, it is too easy to bump way too fast or slow. Is this the way all new LT35 feed control operate? If so I Really do not like.
Offline SawyerTed
  • Summey Lumber Services, LLC
Re: WoodMizer lt35 HD Feed Control Knob
« Reply #1 on: September 13, 2021, 10:42:39 AM »
Mine isn't especially loose.  It doesn't take much to move it but it stays put.  On other equipment that had a loose control like that, I put a felt washer between the cabinet and the knob to keep the control from moving so easily.
Woodmizer LT35HD25, WM BMS 250, WM BMT 250, Kubota MX5100, IH McCormick Farmall 140, Husqvarna 372XP, Husqvarna 455 Rancher, Ram 3500 6.7 Cummins
« Reply #2 on: September 14, 2021, 02:03:13 AM »
Yep, I was thinking doing something like the felt or something to provide some resistance, if in fact that's the way they come from WM and dont need replacing.
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #3 on: September 15, 2021, 09:32:36 AM »
   Never had any problem on mine. I guess I assumed I could just tighten the little flat head screw in the middle to adjust it if I ever need to.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #4 on: September 15, 2021, 09:09:14 PM »
I very seldom remove my hand from the power feed control knob when I am sawing.
Offline Durf700
« Reply #5 on: September 19, 2021, 01:58:37 PM »
I keep my hand on it as well while in the cut.
power feed on LT35
Started by MTMALONEY2 on Sawmills and Milling
Last post November 21, 2017, 12:52:53 AM
by MobileSawMilSlo
Intermittent Feed Problem on LT35
Started by SawyerTed on Sawmills and Milling
Last post October 26, 2020, 06:23:03 AM
by SawyerTed
Power Feed problem on LT35 Hydraulic
Started by WV Sawmiller on Sawmills and Milling
Last post August 16, 2021, 11:00:31 PM
by WV Sawmiller
Wood Mizer Power feed LT35 and LT40 new design
Started by MartyParsons on Sawmills and Milling
Last post December 05, 2017, 12:11:12 AM
by MartyParsons
