Drying vertically
Started by otherguy, November 03, 2021, 02:58:36 PM
otherguy
Has anyone tried drying wood like this?
otherguy
Wow, can't believe no one has tried it, guess I'll see how it goes.
barbender
I think I've seen guys post about how this was done down south with pine, but just for initial drying to keep it from molding in stickered stacks during high humidity. I don't think anything is long term dried like that, but I could be wrong.
Crusarius
I would expect smiley boards but I am very curious to know how it works out.
YellowHammer
I agree, I wouldn't expect perfectly flat boards, I would expect some twist and bow when stacking completely unconstrained.  I wouldn't want the ends touching the ground either, inviting termites and such.
I'me sure the boards would dry, but they wouldn't dry "flat."  For rough or construction wood, I'm sure it would work.
For "flat" I mean I try to get less than 1/8" bow per 8' and 1/16" or less of cup.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
This is the way framing lumber was stacked for drying here until at least the mid 50's and I watched my granddad rotate the lumber many times.  He would flip it end over end and also rotate any boards that he thought needed it.  All of the smaller sawmills had rows and rows of their lumber stacked as shown.  I do not recall ever seeing flat stacks of stickered lumber.
WV Sawmiller
   I saw it stacked like that in Okinawa Japan and several places in Central and southern Africa. I don't think it will dry anywhere near as flat as what we are used to seeing or would accept in the USA.
