When you say you lost power, is it an actual power loss or is it just not working? You need to be careful switching modules as they are not all the same, different programing. The steering and the boom is run off the one valve on those machines, so you may have a hydraulic issue. Could be as simple as a seat switch. Does it have a blade and does that still work?
