Table top finish
Started by Texas Ranger, September 20, 2022, 11:45:01 AM
Texas Ranger
Looking for wisdom.
I have tried several over the years, each seems to have a hickup, or I do with them.
What do y'all recommend for spray. Newer stuff I may not recognize
doc henderson
inside I assume, what kind of wood.  who will use it, commercial or family.  I love to spray but on large projects do not discount the wipe on poly like a Danish oil, hard wax oil, or general finishes arm-r-seal.  I was schooled by @tule peak timber to use pour on bar top epoxy, but not in a single 1/4 inch fake looking pour, but in many thin applications with sanding in between.  on the shoe rack shelf, I used a brush on wipe off, or you can get missed spots, and edges that show.  I spray a lot of the minwax helmsman uv protected poly.
Danish oil natural
this is the thin application of bar top epoxy.  started with thin penetrating then did the edges with some sawdust mixed in to make all stable.
Texas Ranger
Thanks, Doc, I have used a lot of Minwax, also used Deft on some projects.  This an interior dining table, old, have not identified the wood other than light color, heavy and hard.
firefighter ontheside
I sprayed laquer on the last table I built.  It turned out ok, but I have hiccups with spraying laquer.  For tables I fall back to brushing on oil based poly.  I shy away from spraying oil based poly, because I don't like to clean up the sprayer after using oil based poly.  I have used some low voc poly from Target finishes.  I did not spray it, but I certainly could.  It's worth looking into.  It's water based but is supposed to mimic the look of oil based.
Woodmizer LT15
Kubota Grand L4200
Stihl 025, MS261 and MS362
2017 F350 Diesel 4WD
Kawasaki Mule 4010
1998 Dodge 3500 Flatbed
customsawyer
A few of my local customers that build tables, counter tops and bars have gone to using Flooring poly for the finish. They say it isn't as difficult as epoxy with air bubbles and such. It still has a nice look and can take some abuse.
www.thecustomsawyer.com
69bronco
Last table I did this summer I used floor finish, 5 coats.
Danny, how does that hold up to a wet glass sitting on a table for a long period of time.  That's my only reason for not using water based products on tables, especially kitchen.  My dining table has about 5 coats of oil based poly and I can leave a wet glass on there forever and it doesnt leave a ring.
Woodmizer LT15
Kubota Grand L4200
Kawasaki Mule 4010
kantuckid
One of my go to finishes for such a table is three coats of Danish Oil (I use WATCO natural) then with the prescribed 72 hours or longer, then either Minwax or Watco poly satin wipe on finish. They are both, either brand, the same stuff.
  For some sort of "perfection" a sprayed lacquer is what they'll all have in a furniture store. A low VOC, EPA compliant finish always is on commercial stuff.
  I have much spray experience in AB work and equipment but mostly never spray my furniture builds.  Danish Oil deepens colors and pops the grain, poly wipes are the durable aspect for a table top. You could skip them on the table skirts and legs using only the oil below. My own dining table is hand varnished using WATCO Danish then old fashioned oil based (non poly) Waterlox Varnish. It's pricey but it top notch stuff! My great room wide oak board floor I made also has Waterlox satin varnish on it. Wife use some Walmart Orange glo now and then so a durable, easy to maintain finish.
Thats my top suggestion-Waterlox Satin varnish
High end (rich folks furniture) that's custom made will have several choices of finish depending on who built it.
Wipe on's offer application control that replaces the need to spray with the last few coats. I brush on the two early coats with most woods then wipe them.
I remember years ago when doing a gunstock I'd put on dozens of coats with an oil (Linseed based oil with a drier added) like Tru-oil. No longer makes sense for me.
Tom K
It comes down to what expectation you have in terms of looks and performance.
Your not going to get a finish as smooth brushing as you would spraying. I've sprayed quite a bit of lacquer, but a table top is not the place for lacquer. I learned that lesson quite a few years ago, it just isn't durable & hard enough. Maybe some of the newer post catalyzed lacquers have come far enough to hold up ok, but the pre-cat. I used 10 years ago didn't cut it.
Most Pro's would probably recommend a urethane or 2k poly for tables, but that might be a little over kill for your personal use. I can't comment on any of the oil finished as I haven't used them, but I would like to try on some smaller pieces in the future. The epoxy method Doc mentioned sounds very durable. I've been stuck in the world of painted built-ins lately and haven't done any clear finishes in a few years.
I know it's more of a personal bias, but there are much better finishes out there then Minwax. My bias is more towards there stains then there finished though. I very much dislike using their stains. General Finishes, Target Coatings, and even Sherwin Williams has some decent products.
scsmith42
In terms of durability for a table top finish, it's hard to top post catalyzed conversion varnish.  Most commercial restaurant tables use this finish.
There is now a water based version too.
When I don't want to break out the spray rig, on oak I've been starting with pure tung oil thinned with d-limonene, and then top coated with Gleam marine varnish with some Penetrol added to help smooth out the brush / roller marks.  That's how this 48" wide QSWO slab table top is finished.  The Gleam is the satin version.  One nice thing about Gleam is that you can sand it after 3-4 hours and recoat the same day, versus waiting 24 hours for tung oil to cure.
This is a table top of a pair of bookmatched copper beech slabs from a tree planted by Teddy Roosevelt and that grew at Sagamore Hill.  It died while standing, and had a lot of spalt in it.  It was first treated with pure tung oil.  Then the spalted areas were stabilized with a thinned epoxy (RTG Wood Rot Repair Epoxy), with a thin coat spread across both faces.  It was then sprayed with water based post catalyzed conversion varnish on both sides, and polished on the show side.
The red maple bookmatched slab island top below was finished with Tung oil followed by satin conversion varnish.
Another couple of tung oil / conversion varnish tops:  The top one is bookmatched white oak, the bottom one is a single 44" red oak slab.
Tom's 3638D Baker band mill
Walnut Beast
Great information and pictures 👍
Tom K
Great work there SCSmith.
I remembered last night that I forgot to mention conversion varnish. CV finishes have been a mainstay in commercial finishing for decades. Usually the go to for kitchen cabinets and other high use areas, and yes a lot of table tops. A CV would fall between post cat. lacquer & a 2k poly on the durability scale. My understanding is that as the urethane & 2k poly finishes have become more user friendly most have switched to them for table tops.
My hope is to switch over to all water base top coats in the future. I look forward to trying to spray some of these water based poly's, lacquers, and CV's.
I don't think it has been mentioned in this thread, but it's worth repeating. Make sure you put equal coats of finish on each side of the top to equalize the moisture. If not one side will be more susceptible to moisture loss/gain and can cause warpage and movement.
Tom K
Since ScSmith and I both mentioned catalyzed finished I figured it might be worth a quick explanation for those that may not be familiar.
Any off the shelf poly, varnish, lacquer would be a single part un catalyzed finish.
Off the shelf lacquer would be a nitro lacquer, easy to spray but not super durable. No shelf life limits.
Pre cat. lacquer would typically be catalyzed at place of purchase, more durable then nitro, typically 60-90 day shelf life.
Post cat. products, either CV's or lacquers, you will catalyze on site and typically have a pot life of anywhere from 2-16 hours.
Your 2k poly's, urethanes, epoxies are all two part products.
That's a very short/brief run down.
kantuckid
When Walmart took WATCO's Tung oil off the shelves I bought every can. They also took The spar varnish down too and we were in FL winter triping and as we stocked up on food moving around I bought varnish up when still there. Watco tung can be used underneath and I have done so as an oil to pop the grain & color under another topcoat. It's a tung oil combo with driers that make it easier to use than pure tung.
Those a beautiful slab tops!
Texas Ranger
Gentlemen, you have been most educational, now, identify the wood in this top, please.
Looks a bit like oak that has iron filings in the pores from finishing with steel wool and turned black from the tannin. But just a guess.. pic just a bit out of focus.
scsmith42
I can't tell but it looks asian to me.
Texas Ranger
Quote from: beenthere on September 23, 2022, 05:08:18 PM
I have been out of focus for years.
kantuckid
Is it an old veneered oak pedestal table? They often have White oak top layer thats similar when veneered.
Texas Ranger
Four legged dinning room table. I am thinking white oak, now, and is the hardest veneer I have ever worked.
kantuckid
One technique, fuming, that only is possible with acid woods like oak and chestnut is an ammonia treatment either by fumes or swabing on the aromatic the juice. I've done the nearest easy process, swabbing on several projects over the years. It causes what becomes an in the wood, antiquing effect unlike any other. Our American Chestnut kitchen island is my most recent version. It's got a pure black African granite top (with inherent sparkles) which fits well with the darkened chestnut cabinet below. I buy "janitorial strength ammonia" from Ace Hardware for couple bucks, as it's faster working than the regular Walmart or grocery stuff. It opens yer sinuses pretty good but not dangerous as is fuming which calls for a cabinet to hold the entire project and an industrial product to fume with.
Done lazy style, you simply swab the wood and let it dry a day or so. All finish must have been removed! It will raise the grain some, not a lot, so lightly sand with a finish paper like 220/320 afterwards before you proceed.
It gives a look that appeals to me especially on old furniture. It would tend to blend with that darker wood pore mentioned earlier in the thread. Yes, WO is hard. Is the pic showing sanded wood or stripped, un-sanded wood?
I think unmentioned so far is the dreaded finishers nightmare called silicone! The housewife's go to furniture goop is Pledge (or similar) which is a silicone spray. Silicone causes what are called fisheyes in most any finish known to man. It's tough to get rid of to say the least and almost guaranteed to be on any old furniture or newish  :D Google some ideas for removing it which will usually involve several attempts, never a one time and all is well idea.
I've fought it in AB work tooth and nail, especially with new plastic parts which have mold release compounds or old parts with silicone polish residue.
Texas Ranger
I stripped the top twice with two different strippers.  The top had been refinished 25 or 30 years ago, but not the leaves.  The tops "new" finish came off with the first stripper, the leaves, not so much.  For uniformity I stripped the top again, and sanded all.  Did I say this was the hardest veneer I have ever worked?
kantuckid
Strippers are lawyered up and far from as effective as once was. I have a gallon of "aircraft stripper" that won't touch old paints on antiques. The gels and goopy versions seem to work better from box store strippers.
I'd rather build a table anytime than re-finish one.
It's also tough to find gloves that stand up to protect your skin from many strippers, even though they work poorly. The ones that protect are like Army chemical gloves...
doc henderson
@kantuckid I am not sure that a subject about latex protection from strippers is appropriate for this family oriented forum.   :snowball: :snowball:   8) 8)   :o :o  :D :D :D :D
aircraft strippers?  @Texas Ranger did something twice with two different strippers, and Kantuckid has strippers that are lawyered up...
all this talk about Asians and housewives... i think you guys are on the wrong forum!!!   :D :D
