Author Topic: Head Drive Chain Slack  (Read 2070 times)
Offline bugdust
« on: November 03, 2011, 06:44:35 PM »
While sawing the past couple days I noticed slack in my LT 40 head drive chain, even to the point it began bouncing up and down while the head traveled along the carriage. The mill has less than 350 hrs. so I wouldn't expect to see this so soon. I tightened the chain adjustment a couple threads and it seemed to help. I'm curious if this is normal, and why the slack so soon?
Since I retired I really like work: It fascinates me. I can sit and look at it for hours.
Offline WH_Conley
  • I need to tide my profile!
    • Stone Hill Hardwoods
Re: Head Drive Chain Slack
« Reply #1 on: November 03, 2011, 06:48:39 PM »
Probably just worked out the packing grease, burrs on the chain and any other foreign material that accumulated. I wouldn't worry about it unless I had to do it again soon. You should have the slack out of it now. Probably just needed to break in.
Bill
Online Chuck White
  • Sawing Mobile since 2005
« Reply #2 on: November 03, 2011, 07:28:20 PM »
The book says that "normal" slack should be about 2" drop in the middle with the head all the way to either end.
I think that what you're seeing right now is normal.
Same thing as with a motorcycle drive chain, after a few hours of operation it needs to be adjusted.
A few years ago, we took 2 links out of my FIL's feed drive chain.
Of course that one's been going since '92.
~Chuck~
Retired USAF 1989, Retired School Bus Driver 2012, now semi-retired Mobile Sawyer, 2018 Silverado 4X4
1995 Wood-Mizer LT40HDG25 Kohler - Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline T Welsh
  • Woodmizer LT-40-HD http://www.welshtreeservice.com
    • Welsh Tree Service
« Reply #3 on: November 03, 2011, 07:44:52 PM »
I think its normal,its about that time it needs to be tighten. it lives in a bad environment,I wire brush mine every 2 or 3 months and spray it with ATF once a month or so. Tim
Offline ladylake
« Reply #4 on: November 03, 2011, 07:59:57 PM »
  I'd agree any new chain will get slack in the first hours of use.   Steve
Timberking B20 15000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Suffolk  setter Volvo MCT125c skid loader
Offline Brucer
  • The Kootenay Sawyer - retired (for now)
« Reply #5 on: November 04, 2011, 01:53:05 AM »
My book says with the head at the front of the mill, the chain at its lowest point should be 7-8" below the top of the top rail. The main frame tube is 8" deep and the rail is 1" high, so you can eyeball this pretty easily.
When a horizontal chain (or rope) is very tight, any pull downward (say from gravity) results in a very, very high tension in the chain. As the chain sags, the tension becomes less. This means a chain that is too tight is going to stretch ... and sag ... and have less tension.
Bottom line, if you pull your chain too tight, it will end up sagging to where it "wants" to be anyway. Unfortunately a too-tight chain is very hard on the carriage drive motor.
Bruce    LT40HDG28 bandsaw
Offline dean herring
« Reply #6 on: September 07, 2021, 08:00:36 PM »
Anyone know the chain size on a Timberking 1600. I need to take link out.
Failure is not an option  3D Lumber
Online WV Sawmiller
    • Green's Sawmill Services
« Reply #7 on: September 07, 2021, 08:27:54 PM »
   I just replaced cam follower bearing and a feed motor on mine so I can only advice keep it within the specs in your owners manual. I think too tight will cause you way more problems than too slack.
Offline John S
« Reply #8 on: September 08, 2021, 08:31:22 AM »
Yes, 7-8 inches below top of the rail. I wipe ATF on the chain before each day of milling (I use the cut off from an old sock).
2018 LT40HDG38 Wide
Offline Crossroads
  • letís make some sawdust
    • Kevin Bales faith family farm and portable sawmill
« Reply #9 on: September 09, 2021, 09:15:02 AM »
I bought a squirt bottle at the orange box store and was filling it with atf to do my daily lube. Then one day I decided to try to thread the squirter onto a bottle of atf and it worked. A little to loose is better than a little too tight when it comes to chains.
2017 LT40 wide, Kubota l185dt, 2-036 stihl, 2001 Dodge 3500 5.9 Cummins, l8000 Ford dump truck, hr16 Terex excavator, Farmi logging winch, Valley je 2x24 edger, Gehl ctl65 skid steer
Using Stainless Steel for the sawmill head travel drive chain -- pros/cons
Started by pine on Sawmills and Milling
Last post March 31, 2020, 11:33:20 PM
by Crossroads
Oregon Chain "Slack"
Started by deminin on Chainsaws
Last post December 23, 2020, 07:06:17 PM
by sharp edge
Converted Saw Head to Hydrostatic Drive
Started by Wintergreen Mountain on Sawmills and Milling
Last post November 24, 2010, 08:11:12 PM
by fishpharmer
gears for saw head drive system
Started by larrydown60 on Sawmills and Milling
Last post April 02, 2017, 06:39:29 PM
by Kbeitz
