Author Topic: need to but blades, going to try woodmaxx  (Read 1695 times)
Offline peterob
« on: May 26, 2014, 12:46:44 PM »
there for a woodmizer lt28,  would you buy the 7  or 10  pitch,  there 158, 1.25   42  /45   new to sawing an want the best all around blade    thanks for the help   peter
Offline ladylake
Re: need to but blades, going to try woodmaxx
« Reply #1 on: May 26, 2014, 02:26:39 PM »
 If sawing much hardwood go with the 7 as they will saw softwood just fine also.   You are talking about    not pitch.  Pitch is how far the teeth are spaced apart with 7/8" being the most common, I run 3/4" pitch for spruce now, also some run 1" pitch but I've never tried them.   Steve
Timberking B20 15000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Suffolk  setter Volvo MCT125c skid loader
Offline barbender
« Reply #2 on: May 26, 2014, 03:54:31 PM »
I like 7 blades for all around use, they seem to do better in difficult species. Go with the .045 thickness.
Offline drobertson
« Reply #3 on: May 26, 2014, 04:13:24 PM »
this is good advice,
got the sample a month or so ago, .045 7's not too shabby, in fact cut real good, pitchy pine, some with knots, no issues at all.
Offline woodNthings
« Reply #4 on: May 26, 2014, 04:28:56 PM »
I do agree! My 18HP mill is happiest in general with a 7 blade ;D
'10 WM LT33 Hyd.
'80s Case rough terrain forklift
'54 Farmall Super A
'01 Duramax
Offline barbender
« Reply #5 on: May 26, 2014, 07:23:59 PM »
Please understand that I have only run 10, in several brands, and the 7 in WM. I've heard that the 4 is good for difficult hardwoods, I had one to try but all I had to saw was knotty pine. It didn't do that well for that.
Offline drobertson
« Reply #6 on: May 26, 2014, 08:51:01 PM »
the woodmax in what I sawed in knotty, pitchy pine did good, real good. 7 degree,045, conditions vary for sure, as do mills,
Offline slider
  • sawyer,trucker,tree service
« Reply #7 on: May 27, 2014, 03:45:50 PM »
Ladylake ,let us know if you try the one in. pitch band I am curious how it performs .I don't cut much hardwood and 7/8 pitch works well in softwood for me.You hear much talk of hook angle and kerf settings but not much on different pitch .I know it's not a fair comparison but a while back I switched to a skip tooth chain over the standard one on my stihl and it was a big improvement.I guess the density is a big factor .
On a band mill I think horse power may have an influence on pitch ,could be wrong.I have heard the 7 degree wm bands turbo I think need a fair amount of power to perform well.Have not tried any yet.Al
al glenn
Woodmaxx blades
Started by petefrom bearswamp on Sawmills and Milling
Last post May 24, 2014, 10:41:51 PM
by hamish
WoodMaxx Blades
Started by WellandportRob on Sawmills and Milling
Last post December 08, 2015, 06:45:31 PM
by KamHillbilly
Please Welcome KASCO SharpTech & WoodMaxx Blades!
Last post December 22, 2014, 07:15:25 PM
by Billbob
Woodmaxx sawmills
Started by AndyVT on Sawmills and Milling
Last post November 29, 2021, 08:35:31 AM
by VB-Milling
