Author Topic: Blade Tension on LogMaster LM1  (Read 1299 times)
Offline BlueSalt
« on: October 07, 2014, 06:22:26 PM »
Recently purchased a LM1 sawmill from widow, only to find they went out of business.  Does anyone have information of blade tension or source to get a copy of operators manual?
Offline Grizzly
  • I wanna go camping!
Re: Blade Tension on LogMaster LM1
« Reply #1 on: October 07, 2014, 08:59:37 PM »
I run an LM2 with .042 x 1.25 bands and the unit came with instructions to run 6000psi. Due to my balmy northern location (Saskatchewan) I've lowered it to 5000psi and it has worked well. Not sure what blades you run on the LM1 but that is the best info I can give.
2011 - Logmaster LM-2 / Chinese wheel loader
Jonsered saws - 2149 - 111S - 90?
2000 Miners 3-31 Board Edger
Offline BlueSalt
« Reply #2 on: October 08, 2014, 10:28:11 AM »
I appreciate the reply, but the LM1 does not have hydraulics.  I will need to use a torque wrench.  I am using
cooks-xcel-black-147-1-1-4-x-.042-x-7-8-blades.  Thanks.
Offline thecfarm
« Reply #3 on: October 08, 2014, 06:41:17 PM »
BlueSalt,welcome to the forum. I have a manual mill. I have always just tightened it up and pressed down with my thumb.  ::)  But so far,it has worked.  ;D
Offline ozarkgem
  • age 65 yrs old
« Reply #4 on: October 08, 2014, 07:40:37 PM »
if your blade is vibrating while running, tighten it up till it runs smooth. That is my system.
Offline shortlogger
« Reply #5 on: October 10, 2014, 08:54:17 AM »
Tighten your blade to 40lbs on your tourqe wrench . That's what the spcecs call for
1 Corinthians 3:7 So then neither he who plants is anything, nor he who waters, but God who gives the increase . "NKJV"
Offline shortlogger
« Reply #6 on: October 10, 2014, 08:55:19 AM »
I have my manual if you need to know anything else
Offline BlueSalt
« Reply #7 on: October 10, 2014, 10:36:33 AM »
Thanks Shortlogger.  That is what I needed to know.
Offline Solomon
  • I finally figured out how to upload pictures!!!!
« Reply #8 on: October 13, 2014, 08:28:38 AM »
I have the LM4   I tighten it up to 6000 as well.   The LM1 runs at about 4500.  My sugestion to you is make it reasonably tight and try it.  Then tighten it a little more and so on until it cuts they way you desire in any given spiecies.
 "Sneak up on it" so to speak.
You will know when it's right.
Time and Money,  If you have the one, you rarely have the other.
The Path to Salvation is narrow, and the path to damnnation is wide.
moved
MOVED: Blade Tension on LogMaster LM1
Started by Roxie on General Board
Last post October 08, 2014, 05:57:01 PM
by Roxie
Logmaster edger blade source?
Started by Old Greenhorn on Sawmills and Milling
Last post September 14, 2021, 08:51:52 PM
by Old Greenhorn
DIY ,Blade tension
Started by coyotebait on Alternative methods and solutions
Last post July 18, 2017, 04:28:29 AM
by Kbeitz
blade tension on WM
Started by petefrom bearswamp on Sawmills and Milling
Last post June 08, 2018, 10:22:48 PM
by Chuck White
