Author Topic: Frick Edger re-power  (Read 2313 times)
Offline doncny
« on: October 05, 2015, 10:03:33 PM »
First post, so a quick introduction.
I live in central ny, about smack in the center of Oneida County for you other CNY folks.
I have a home-built mill, started as a Linn design, added power up/down/feed, and hoping to add some hydraulics over the winter.
Saw mostly for myself and sell what excess lumber I have to people I know, although lately, my stacks are shrinking, seems like logs have gotten harder to come by here this year.
Recently purchased a 27" Frick dual blade edger.  It was powered by a 7.5hp 3 phase electric motor.  But since I don't have power out to my mill location, I was going to convert it to gas engine.
Looking at other edgers like a WM, they have 25 and up horsepower.  Does an edger really require that kind of power?  I was thinking of putting a 13hp single piston engine on, but now I am thinking it needs something more.
I think the Frick can edge up to 12/4 but I mostly run 4/4 in hardwoods, and 8/4 in softwoods.
Anyone else run an edger with less than 15 hp gas, or do I need more.
Homebuilt Linn design sawmill
Frick edger
Offline Kbeitz
  • Never enough time...
    • My Hobbies
Re: Frick Edger re-power
« Reply #1 on: October 05, 2015, 10:46:09 PM »
My neighbor powers his with a 600hp detroit diesel... Not a type-o ... 600 hp
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline Ron Wenrich
  • Forester
« Reply #2 on: October 06, 2015, 05:54:25 AM »
The more the better.  You might be able to get by with a 13 hp. If you have one on hand, give it a try.  If it doesn't work, then go out and get a bigger one.  We ran a 50 hp electric in our mill, but had used a hydraulic motor prior to converting to electric.
Where you might get in trouble is when you have 2 blades in the wood or are in thick stock.  If you're not cutting much, you could use just one blade in the harder wood or thicker stock.
Offline doncny
« Reply #3 on: October 06, 2015, 01:15:49 PM »
Wow, 600hp, bet that does not even change rpm when edging.
I do have the 13hp engine already, but have a 22hp I could buy.
I know it is always better to have more HP, maybe I will just go with the 22 HP to start.
Still a little ways from powering it up. It spent some time outside and somewhat rusted up, but have most everything moving albeit stiff still.  And have to figure out pulley sizes to get back to the right input shaft rpm.
Frick edger
Offline JB Griffin
« Reply #4 on: October 06, 2015, 02:10:28 PM »
I believe that it was Ron that said, on a head saw 2-3hp per tooth, can't see why that wouldn't be a good starting place for an edger.
2000 LT40hyd remote 33hp Kubota with 6gpm hyd unit, 150 Prentice, WM bms250, Suffolk dual tooth setter
Over 3.5million bdft sawn with a Baker Dominator.
Offline plowboyswr
« Reply #5 on: October 06, 2015, 03:14:27 PM »
First off welcome! Some years ago when we were looking at converting our irrigation pumps over to electric we were told 1hp electric equals 3hp fueled ( gas or diesel). Don't know if this helps or not, just pitching in my .o2 ;D
Just an ole farm boy takin one day at a time.
Steve
Offline Ron Wenrich
  • Forester
« Reply #6 on: October 06, 2015, 07:38:51 PM »
Rule-of-thumb is 5 hp per inch of wood per saw.
Offline JB Griffin
« Reply #7 on: October 06, 2015, 09:55:35 PM »
Ron, is that for edgers or circle saws in general??
Offline Ron Wenrich
  • Forester
« Reply #8 on: October 06, 2015, 11:48:36 PM »
Circle saws in general.  That was given to me from a guy that sold and installed mill equipment.
Offline JB Griffin
« Reply #9 on: October 07, 2015, 08:38:30 PM »
Thanks Ron
Offline jeep534
« Reply #10 on: October 16, 2015, 08:54:37 PM »
so where are the pictures
archie
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #11 on: October 17, 2015, 07:42:42 AM »
I would suggest as much power as you can get. I've run a two blade edger with ten hp electric, and it would do it, but only at about 20 fpm. My 26 hp CAT diesel will run at 80 fpm.
Frick edger without power source.
Started by TnSawyer on Sawmills and Milling
Last post June 16, 2007, 08:38:13 AM
by Dave Shepard
Frick 2-27 edger
Started by moodnacreek on Sawmills and Milling
Last post June 17, 2021, 07:49:20 PM
by barbender
Frick edger
Started by Patrick NC on Sawmills and Milling
Last post June 02, 2021, 12:35:52 PM
by moodnacreek
Old Frick edger
Started by woody1 on Sawmills and Milling
Last post October 14, 2015, 10:09:31 PM
by jeep534
