kiln load
Started by xlogger, December 19, 2015, 05:29:38 PM
xlogger
How many bd ft of 4/4 wood like poplar and maple wood that dried to 20% or less can you put in a Nyle 53.
YellowHammer
Quote from: xlogger on December 19, 2015, 05:29:38 PM
The manual says 300 Bdft when dead green, but usually I'll put in 600 when mostly air dried, say under 20%. Typically, it'll do a load a week.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Under 20%, I usually put in 750 - 900 BF, no matter the species.
xlogger
How about mixing them up?
Better not to, but I do it.  It is a matter of practicality.  I have not had any issues if they go in air dried.  From green, there would be many more issues.  I have not mixed green loads, just air dried loads that are around 14 - 18% moisture.
