Author Topic: Oregon chain does not fit Oregon bar  (Read 840 times)
Offline Trailace
« on: September 12, 2020, 03:40:00 PM »
This is my first post on this great site. Lots of great information here thanks to everyone who helps out.
So my first question is about a Oregon bar and chain. I just pick up a new MS 461 with 25 bar but wanted to run this saw with a 20 bar. I ordered the bar and chain listed on Oregon web site but the chain will not fit in the grove of the bar. I dubbed check and all the number seem right. Sent the bar back and ordered another one. Same issue. Here are the parts numbers. Chain 72LGX072 and bar 200RNDD025. So what am I missing Any help will be appreciated.
Online lxskllr
  • dummy with saw
Re: Oregon chain does not fit Oregon bar
« Reply #1 on: September 12, 2020, 05:07:57 PM »
Welcome!
Looking online, your numbers appear to be correct, but if it isn't fitting the groove, there's clearly a gauge mismatch. I'm not familiar with Oregon's system, so maybe their numbers can cover multiple gauges?
Copy/pasting a comment from @John Mc check your bar/chain with coins if you don't have calipers or anything...
"My 36 bar gauge checker: A dime, a penny, and a quarter. Each coin should fit snugly in the groove of the indicated bars:
   Dime    = .050
   Penny   = .058
   Quarter = .063
Offline sawguy21
« Reply #2 on: September 12, 2020, 06:57:03 PM »
Do the drivers on your 25" bar fit? I am assuming it is 33RS which is .050 gauge, if it fits the Oregon chain is incorrectly labelled.
Offline charles mann
« Reply #3 on: September 12, 2020, 07:26:13 PM »
Its probably an issue with the chain, not the bar. If you dont have a caliper, a set of feeler gauges will work to find the thickness of the chain drive tooth.
I was running a jonesred 2166 and bout a 20 bar for it and accidentally bought (wrong labeled box) a 0.063 chain instead of the 0.050 i needed.
Check your chain, probably gonna be the issue
Temple, Tx
Offline sawguy21
« Reply #4 on: September 12, 2020, 08:23:50 PM »
What number is stamped into the drive link?
Offline Tacotodd
  • To learn and help
« Reply #5 on: September 13, 2020, 12:26:53 AM »
Go with @sawguy21 answer and @lxskllr  response about that $0.36 , low buck feeler gauge kit (as far as bars are concerned).
Trying harder everyday.
Offline Tacotodd
  • To learn and help
« Reply #6 on: September 13, 2020, 12:28:52 AM »
And welcome aboard @Trailace .
Offline Trailace
« Reply #7 on: September 13, 2020, 10:03:19 AM »
Thanks for the replies guys. Went back to the shop last night and tried one of the other 20" chains and bingo it worked. Not sure what is wrong with the first chain but maybe it was pack wrong or I mixed it up. Thanks again for the help.
Offline Trailace
« Reply #8 on: September 13, 2020, 10:04:02 AM »
Offline Dale.NZ
  • NZ Forestry Industry
    • TERRAIN
« Reply #9 on: September 13, 2020, 04:54:15 PM »
Sounds like you're already sorted but just in case someone else is looking for the correct chain:
- assuming 3/8 pitch + semi chisel here in NZ for the .063 stihl gauge we use Oregon's 75EXL chain for our foresters
Yep, retailer -- but I'm learning not selling!
Offline John Mc
« Reply #10 on: September 16, 2020, 12:35:55 PM »
I believe Oregon 75EXL is a full chisel chain.
Offline sawguy21
« Reply #11 on: September 16, 2020, 01:48:54 PM »
I sold Oregon chain for a few years, don't recall any 75 series going out the door. We moved some .404x.063 for the guys with big Stihls on the coast.
Offline John Mc
« Reply #12 on: September 16, 2020, 04:03:21 PM »
I've got a couple of loops of 73EXL waiting to try as soon as I use up the 73LGX I have on that saw now.
Offline Dale.NZ
    • TERRAIN
« Reply #13 on: September 16, 2020, 05:15:59 PM »
Yeah, you're correct @John Mc  ---> it is full chisel. My mistake.
We've used the 75 series as our 063 gauge chains and the 73 series for our 050 gauge, but we're in NZ so I'm not sure if it changes anything.
Offline John Mc
« Reply #14 on: September 16, 2020, 05:48:24 PM »
73 series is 058.
72 series is 050.
Offline Real1shepherd
« Reply #15 on: September 16, 2020, 05:49:19 PM »
Oregon 68CJ is square file, skip-tooth .404x.063 gauge chain. Been using that configuration most of my life. We never said "full-skip", but skip-tooth. We did say "full-comp" though.
Kevin
Oregon Logging Show in Eugene, Oregon Feb. 22,23,24
Started by tlooney on Shows, Events and Places to meet
Last post February 22, 2007, 01:20:55 AM
by tlooney
Oregon saw chain??
Started by dustyhat on Chainsaws
Last post June 07, 2017, 05:41:35 AM
by Al_Smith
Oregon chain
Started by 6sunset6 on Chainsaws
Last post January 19, 2012, 12:39:43 PM
by lumberjack48
Oregon EXL chain?
Started by John Mc on Chainsaws
Last post November 01, 2018, 06:56:02 AM
by John Mc
